Saturday Night Mountain Cruise 29th Of July Gold Coast
SATURDAY NIGHT CRUISE
29/07/2006
Ok,
Proposed is a Mountain Cruise (Old School Style)
Starting on Southport Nerang Road from the BP service station and cul de sac carparking area on Centeral Park Avenue. (Maps Below)
Following it all the way out to the Natural Arch and back down to the Springbrook turnoff out to mudgerabah then back to Ashmore Tavern Carpark following the leader.
Meet at 8:30pm BP on Southport Nerang Road
Depart at 9:000pm
This will give people time to fill up (for those that use caltex you can convert and be normal........or use the one up the road.) You will need approximately a half a tank of fuel so fill up regardless.
Then we will strike forth to the natural arch.
This will be used as a turn around bay.
Drive back to the Springbrook exit go down towards Mudgerabah. (Great drive)
Then Back to the A
mpol/ local Tavern on Beaudesert Nerang Road/ Price Street/ Southport Nerang Road. (This is the same road, from the BP it is Southport Nerang Road then towards the highway turns to Price Street then towards the mountain turns to Beaudesert Nerang Road.)
CB's are recomended as you may get lost or require the assistance of David Hasselhoff.
Channel will be given on the night.
Northbound and Southbound take Exit 69
The trip is worth it.
Who is up for it?
ALL members are welcome
For those that will be attending this from Brisbane can someone please put the old hand up and arange a meeting place up there somewhere.
Those that are not at the meeting place on time will sadly miss out.
I feel that a 30 minute window is big enough.
If you have a skyline or even a moped i dont care if your on the site be there or be squizaire
For more detailed directions use Whereis.com or a simple refedex to find the meet place.
If you get lost call me on 0405987261
Cautions:
These roads are out in the bush/forrest, please keep a distance between you and the car infront to compensate for posible braking due to wildlife.
If you can tell the person behind wants to overtake you indicate to the left to notify them they can safetly do so.
As my car is receiving a rather large rectal thermometer (RB3026) i will be attending in a white series 2 skyline and will respond to name calling.
Those who are more circular and not square who will be attending.
Slide Aaron (me)
SkylineSII
SirSkyline
BDW06
Bunta - impact_blue
Lazy-Bastard
MajorSick
SLI-Line
Alfadog
  • Replies 41
Heh I would never have seen this if it wasn't linked to from another topic in the Qld section.
Anyway, bitching aside, the meetup point is seriously like 5 minutes from my house, CRAZY! I think I'll be in, have never been on a "night cruise"...
I'm not about to thrash it up any mountains though, I hope we will be driving at a SENSIBLE speed?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
