G'day my names Mick, I own a 1994 33 GTST, no serious mods just
pod filter,
bov,
fmic,
GTR fuel pump,
injectors,
Fuell pressure reg,
dual stage boost controller,
exhaust.
But recently when i give it a bit or gass, it seems as if im hitting boost as the revs jump from 3ish to 4 or 5ish but i get no power gain then the revs drop back down to 3500 and slowly pick up again? and boost isnt spiking as it sits strong at 0.5bar without dropping. There is oil in my intercooler piping to my turbo so im leaning towards my turbo being rooted but i want to make sure its the turbo befor i spend all that cash, as i would hate to buy a new turbo only to find out that that wasnt the problem.
Has this happened to anyone else? or any ideas what it could be?
cheers guys
https://www.sau.com.au/forums/topic/127524-rev-jump/
sorry if sounds stupid but how would this be a clutch problem ??
its just i am having the same problem
If the clutch is worn it'll slip under load.
You know how a clutch works yeah?
Basically as soon as the car hits boost or similar, the worn clutch won't be able to continue transferring the power from the engine. So basically it'll feel/sound like you're just free reving. ie. Engine will rev up quick but the car won't be going any faster.
https://www.sau.com.au/forums/topic/127524-rev-jump/#findComment-2356150
clutch is slipping. time for a new heavy duty one. you'd be in the power band to kill the stock clutch so time for an upgrade. if you keep slipping it, it will fail completely and you wont be able to drive the car, so just baby it around
https://www.sau.com.au/forums/topic/127524-rev-jump/#findComment-2356375
what wil said. :D
https://www.sau.com.au/forums/topic/127524-rev-jump/#findComment-2359600
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
