Where can I get a decent key blank from for a reasonable price? So far all I can find is a Nismo blank for about $100, and a GTR blank for about $60 (I think). I don't have a GTR otherwise I would get a GTR blank. Are there any other options? I really don't wanna fork over $100 just for a spare key, but nor do I want to buy the $5 generic type you get at the local key cutter's.
Even the normal Skyline key (without remote button) would be good enough, if it were relatively cheap. Nissan Australia probably want to charge me $100 for it and make me wait 4 weeks for it to arrive from Japan :P
https://www.sau.com.au/forums/topic/12843-key-blanks/
Originally posted by CMS Drifter
try nissan, u may be surprised
I agree 100%
When i was looking for the front bar indicator assy. I was quoted $120ea for s/h ones from the wreckers.
Whent to Nissan dealership in Dandenong and got them for $75ea brand new (genuine items) and picked them up 7hrs after ordering them.:uh-huh: :P:D
https://www.sau.com.au/forums/topic/12843-key-blanks/#findComment-239968
Originally posted by Al
I agree 100%
Al, are they the indicators in a S1 front bar? I parked into a tow bar today and it went right through my lhs indicator, so will probably need a new one.
also, do u have a part number. cheers,
dave
p.s - sorry for hijacking key thread. I am also interested in a good nissan blank, not a shitty one like the one i got with the car. so if anyone knows a good price for something with nissan written on it that fits a gtst...
https://www.sau.com.au/forums/topic/12843-key-blanks/#findComment-240152
Do all Nissan dealers charge the same price? Because I got a quote for a plenum gasket from Ryde Nissan, they wanted $85 for it, and they wanted the full amount up-front so they could order it from Japan, and it would arrive in 4-6 weeks!
Edit: Which Nissan dealers (esp. in Sydney) are Skyline-friendly? ie, those that will keep some parts in stock, and will know what the hell I'm talking about when I ask for something like a Skyline key, or a bonnet strut clip, or a headlight assembly, etc.
https://www.sau.com.au/forums/topic/12843-key-blanks/#findComment-240486
Originally posted by DAHXX
Hey deorbit,
Which nissan dealer did u get it from?
Nissan Parts & Service in the city. Well Carlton actually. Its on Swanston St. just up from the Melbourne baths.
I work just across the road from it so its kinda convenient, me owning a Nissan and all :P
https://www.sau.com.au/forums/topic/12843-key-blanks/#findComment-249680
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
