hey guys
just looking at peoples opinions on polishs and wax, i currently use autoglym, but not really happy with the shine! im after i shine u can count how many teeth u got! what do u guys recommend? and something thats last im sicking polishing my car every second day
Edited by ali-turko
https://www.sau.com.au/forums/topic/128481-polisheswax/
Internet is a wonderful place.
So many different forums for all kinds of things.
Anyway, here is something I came across on a barge forums.. I mean Soarer forum..
Hope you got some time and money on your hands..
But once you are done, you’ll be able to see that bit of chicken you got between your front teeth there..
http://soarercentral.com/sc-forum/messages...html?1153124760
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2377482
stop telling lies all of you!!!!
This is what i use, and ill follow up with some pics
Firstly i give her a wash using Johsons & Johnsons baby shampoo, with a Meguirs Lambswool wash mit.
Then a chamois with a Meguirs Microfibre chamois
Then a coat of Meguirs Paint Cleaner
Then a coat of Meguirs Deep Crystal Polish
Then leave that overnight
Then a coat of Autoglym Synthetic Wax
Leave that sit overnight
Then a coat of Turtle Wax Carnuaba Wax
This is what it looks like. This is of my old 33, n was a few days after it was all done, will be doing it to the gtr soon.
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2377587
here are the things wrong with that..
do not use human products on the car, is designd to moisture rise a baby, so it has alot of oil in it, which will sit on the surface of your car.. the mits are crap, all they do is scratch as they get cloggd with dirt
its crap
its crap
why?
why? you already used the meguiers, theres no point waxing over wax
why? you already used the autoglym, theres no point waxing over wax
meguiers is shit house, autoglym is much better..
But i use zymol, german products.
http://www.zdoau.com/
it is the best, nothing comes even close..
edit: i could get a better finish that yours, cheaper, and quicker..
wash car.
clay car with 3M paint clay, its removes fallout and other things on the surface.
wax car using zymol cleaner wax ($60) it will fill small scratches and hide swirl marks, has %17 canuba, and will out gloss most other things of the same price ont he market and last longer..
You can get up to %90 canuba in the zymol range, obviously they get more expensive, but its the best..
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2377614
all that stuff was recommended by Will Wax You...so dont ya think they'd know a thing or too about it? :no:
Also the idea of putting on dual layers is to give the efect of both the synthetic and natural waxes. If you look at show cars, they dont just have one layer, and one type of wax, they use mutliple layers of differing types.
Reason u let them dry is so they set, or you dont bring out their true qualities if you just do them back to back.
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2377891
all that stuff was recommended by Will Wax You...so dont ya think they'd know a thing or too about it? :laugh:
no, show cars use natural wax;s with high canuba to give it taht mega gloss, there is no point in waxing over wax, it wont make a difference..
and dont let it dry, thats when you scratch the paint taking it off. i know the techwax is easier to take off dry, but, i dont like it as it gives nasty streaks
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2378702
Well - i just used Meguiars Mirror Glaze Swilrl Remover 2.0
And I still have swirls............
Buggger !
My experience with Meguiares is this:
Dark Blue car with bad swirls...
Deep Crystal Paint Cleaner : to remove old waxes and buildup. (run fingers over paint work..is it rough? buildup!)
Then I used the Swirl Remover... it got alot of swirls out, but not all...
Then I followed up with the hi-tech yellow wax.
It looked alot better!!
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2380146
its not "build up" its fall out, its shit in the air that lands and sits on your car...
If you park at a trainstation youll have rail dust all over your car.
the best way is to clay your car..
also, the swirl remover dosnt remove them, it just hides them, thats why after afew washes they are back,
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2380820
this is a good site as to why you would clay a car, and how
http://www.autogeek.net/megovclay.html
its about $38 for the kit at most auto one/Peps auto etc shops
you buy the kit with a meguirs spray that lubes the clay bar and the small clay bar itself
https://www.sau.com.au/forums/topic/128481-polisheswax/#findComment-2381119
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
