oh and it is unbelivable on petrol i always put premium fuel and 60 bucks will get u a full tank and it can do approx 500km per tank with the aircon. And it has a pod airfilter with chrome shield.
60 bucks will get u a full tank? i reckon u must be talking about yr corolla
N/A run the same size of fuel tank as turbo (60/65L?), assume premium is at $1.4/L, $60 will only get you around 43L.
I know thats what i thought aswell, but i put $64 when the orange light turns on and it fills a full tank, there is no way the tanks are 65 liters even though thats what they claim i believe they a 55L. But yeah i thought they were 65 liter tanks aswell. But every single time i go to the bouser and with the orange light lit up $60-68 gets me a full tank.
Alex
we have 65L tanks in our cars. I've pushed an extra 120Km's in my car with the fuel light on and on that particular tank I had done 620Km's.
Ahhhhh that would make sence cause i was like why would the book lie to me lol. Its good that the light comes on that early its a good indication on when to fill up.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
