There you go, EXACTLY what happened to mine, after 90,000kms I don't blame it.
My nuts were finger-tight too, but i DID have at least 4!!
Cam, we didnt need to undo the oil/water supply lines to get the gasket off hey :D We just loosened the front pipe and used goon-strength to pull it "off" the four studs holding it onto the manifold.
In my endevours I rounded off 2 heatshield nuts (nowhere to mount my EGO sensor bracket now, so it's cable-tied up!) and 2 Manifold bolts. ugh!
'Spose you couldn't have done any worse!
Stric - hmm - me thinking I'll be checking mine - or getting them checked when the dump pipe goes on..
As for the goon like strength - can supply that easily enough (me not smart, can lift heavy stuff but! :D ) - though was hesistant to do that because the turbo seemed to be constrained in it's moment by the hard piped oil line underneath. In other words, I'd rather romove it than chance breaking - Zanda would never let me hear the end of it.. :)
got an update on the novice backyard mechanics for anyone who's interested...
spent the weekend grunting and groaning, trying to remove the coolant lines and the two bolts holding the front pipe to the cat. all of them were fu:) ) we were able to undo the coolant lines and remove the oil lines from the turbo. with all of these lines off and the manifold bolts off - the only thing left holding the turbo in place was the cat/front pipe bolts... no problem.. yea right!
those mothers were waaaay rusted! i recommend anyone who is deciding to do this carry a BIG can of wd40 and a BIG spanner - possibly even a hammer! after much bashing, got one bolt loose and out and the other one snapped cause the thread was so rusted...
while the lot is out - it was decided that a dump pipe should be added before putting everything back...
so - things left to do..
drill out bolt in cat
fix heat wrap around air con lines (damaged when pulling turbo out)
re-attach oil/coolant lines to turbo
replace turbo/manifold gasket (the original job!)
replace all piping
check oil/coolant levels and top up accordingly
give offerings to local god.. start engine.. :P
btw,
thanks to adam32, who offerred his saturday evening input.
as it turned out, the fiasco was justified. Although I speak for myself, I felt much better about spending all that time rolling around on the ground once the piece of rogue gasket turned out to be one inch long.
blade chewage averted.
  • 1 year later...
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
