Hi people
just was wondering which one to adjust to move the power band so ot spools up quicker, do i adjust the inlet or the exhaust i'm hoping it's the inlet cause it's alot easier to get to on the dyno or is a combination of both.
Also these cam gears were on another rb20 and set at +2 -4 i took them out of that engine and just wacked them on mind ( i did the TDC) are they already dialed in to +2 -4 on my engine or do i have to take the cam gears off set them at zero and then put them back on and then adjust it to +2 -4. i hope that made sence
Cheers
anthony
https://www.sau.com.au/forums/topic/128635-adjustable-cam-gears/
Fair enough what about my other question about weather or not i have to re adjust the cam gears.
i.e do i have to take them off set them on zero and then put them back on or are they already set up because they were done on the other motor?? I asked sydney kid and he answered my question but i don't think i made much sence so i just want to confirm. should i take them off and re adjust it or not??
Cheers
anthony
Cheers
anthony
They are already adjusted to the most common setting. Put them on as they are and get on with tuning it.
:P cheers :D
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
