have pulled out my globes that light up the panel in the heater/air con, anyone know where to get from? anyone bought them before? called nissan and $20 for 2 tiny globes, will try wreckers but never know what condition they are in, also looking for the weather shrouds over the drivers window, helps keep out rain.
posted pic and yes car needs a wash but with all the rain hardly seems worth it
Edited by black33_26
https://www.sau.com.au/forums/topic/128863-looking-for-parts/
I have one of those drivers side thingy's, how much you willing to pay.
0434498098
what colour are they? i have red ones but after black, will find out how much they are new and get back to you if you have both?
pic of the globes, too small and pointless to pay that much, would be good to be able to see in dark tho, jaycar dont sell them either, auto elcs told me to call nissan but for 20 bucks get stuffed
*sigh* why dont people either search for items or at least believe others when they ask q's....
:sorcerer:
http://www.skylinesaustralia.com/forums/in...61&hl=grain
http://www.skylinesaustralia.com/forums/in...29&hl=light
http://www.skylinesaustralia.com/forums/in...12&hl=grain
http://www.skylinesaustralia.com/forums/in...29&hl=grain
http://www.skylinesaustralia.com/forums/in...35&hl=grain
unless i, and all the others in the threads ^ are lying id say jacar etc would sell em.
have a nice day
:sorcerer:
have a nice day
went in and they said dont have any, thats how i know they dont have them.
and not sure if they said 20 for both or 20 each, didnt exactly care at that price even for the 2, just looking to tidy up the car as some dodgy stuff done from previous owners, like cutting coin tray to fit ebc, nice yellow glow ready for cops to see
gonna try dick smiths for these grain bulbs, will post pics to see how it turns out
Mmmm not sure if I've seen those 1's before. Do the globes actually pull out of the holder? If they do they're just the grain of rice globes you should be able to pick up nearly anywhere, can't quite tell from the pic.
They don't look original since they are blue, don't know any nissans that use blue dash lighting.
anyone actually bought any of these globes? been to 2 dick smiths (marion shops and st marys), jaycar clovelly pk, lighting stores, super cheap has nothin even close, only thing i found was LED lights and just want the simple 'grain' globe
found the perfect globe and only 70 cents from repco, or can get from auto elec...
part no 47702 dash globe
pic shows exact same size, removed second blue cap perfectly with a 'precise screwdriver' smallest flathead in the pack, angled down on globe and slowly slide up to top.
fixed hazard light also with a grain of wheat globe as same size also. much harder to fix tho
nah have to take out the whole unit, only 2 globes for whole panel, once removed just a flathead screwdriver to get them out from back of unit.
if you want your hazard light working let me know, could probably show you how to do it at the meet and greet.
will take pic later to show all working
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
