Here’s a tricky one…………
SOSK took the R33GTST for a test drive last night after we finished fitting the BOS Importing split dump, which works very well by the way. On the way back home at around 4,500 rpm it spat the power steering belt off (it was an old one) and the engine died instantly. And it wouldn’t restart.
I went out and checked it, in the dark, rather late, on the side of the road. It has spark, the cranking ignition timing is spot on, checked with a timing light. It has fuel, I can hear the fuel pump start and smell unburnt fuel when it is cranking. Usually spark + fuel = start, but not in this case.
I checked for wiring damage from the belt flying off, but I couldn’t see any. The sensor readings on the Commander all look normal. I checked the fuses under the bonnet and under the dash, they all look OK.
Obviously the HICAS light is on, due to the lack of a power steering belt. But that’s all I can see that is wrong. I haven’t had a chance to look at it in daylight or in the garage, I will do that tonight. So I figured I might as well post up the happenings and see if anyone else has encountered a similar problem.
:thumbsup: cheers :P
I think you have another problem....unrelated maybe.
The only other things around that the belt could damage would be the AFM possibly but doubt it. I know you were checking it in the dark on the side of the road but thought I would point out that hearing the pump doesn't mean the engine is getting fuel. Also how did you test spark? And are you certain the belt threw because it was old?
Would be good to see what the problem ends up being.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
