  • Replies 58
It wasn't that difficult, but then again it's a bit of a half-assed job... Here's how I did it and prolly isn't the best way. Wasn't expensive though.
You need a clear panel for this
[*]get the thing off (4 nuts)
[*]remove any silver paint from letters so they are clear
[*]cut the back out in the shape of a letter box (you'll never get it open as it's sealed with goo, grrrrrrrr!)
[*]get some translucent red self adhesive vinyl and stick to inside of panel (mine needed 2 thicknesses to get the colour right) - £free
[*]clean it well and carefully mask letters and black bits (masking the letters took a razor sharp knife and a lot of time)
[*]get (right colour) spray paint and plastic primer - £12
[*]prime, spray to a good thickness
[*]get a neon tube, mine's for a PC case but is a bit short, and fix inside - I used a hot-glue gun near the ends. - £13
[*]test
[*]seal up with whatever you like
[*]tag transformer wires onto tail light circuit
[*]fix it back on
[*]connect up
[*]grin! - £priceless!
[/list=1]
Hardest bits were masking the letters and getting the right colour paint - the QM1 I had mixed was no where near the QM1 the car's sprayed in (apparently there are at least 2 QM1s...).
Cost just over 25 quid ($65 ish). Bargain.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-254975
for r32's this light was a factory option offered by nissan. in the r32 factory optional parts catalogue it was called the "rear finisher" and was sold under the following codes according to body colour.
5NG03~5NG07,5NG09,5NG10
the price at the time was 33,300 yen. i went to tokyo nissan last week to ask for one for my friend. but they ceased production quite a while ago in 1995.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-277086
guys.... i just got pulled up by the coppers. "you arent allowed to have allowed to have any blue lights coming from your car. (its green) the only people allowed to have blue lights are police cars" "it came with the car!" "remove it"
i was lucky to get away with it, because the car was just imported. the fine is $75 and one point.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-318082
AtomicBomberMan
what state are you in, im in WA and the new rule here is that there is not allowed to be anything like on the bonet, but you can have any colour underglow you want aslong as the globes themselve are not visable. So the glow is fine. I had blue LED windscreen washers to and they are illegal because they are visable but underneath fine...Weird!!!!!!
Taking pics tonite so ill have them up on sunday for you guys to check out
cya
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-320003
G'day Moschops
Can I ask, could you explain the following steps. I'm having a lil trouble trying it
How'd you remove it? scratch it off?
How'd you cut it? looks kinda fragile thats all.
Hmmm, any advice on where I can get this from?
May I ask, what black bits are you referring to? I presume you simply used that white marksing tape is that right?
Please advise as I reckon your car looks awesome. Thanks heaps in advance.
https://www.sau.com.au/forums/topic/12932-has-anyone/page/2/#findComment-321674
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
