Hey guys, just bought an oil cooler and have a few q's about the install:
1. On the sandwich plate it says IN & OUT for the hoses, but has nothing on the cooler. Does it matter which hose goes on what side of the cooler or can it flow both ways?
2. Do I need to drain the oil to fit the sandwich plate or can I just change the filter and top up the oil?
3. Once its all connected do I need to crank the motor first or will it not make a difference due to the thermostat?
Thanks, Konect.
https://www.sau.com.au/forums/topic/129357-fitting-hks-oil-cooler/
1. The cooler doesn't care what way it flows
2. You can fit the sandwich plate without dumping the oil but id recommend changing oil at the same time anyway (and also cleaning the lines and core before installation)
3. pull the plug off the cas and give it a crank for 20 seconds or so, then check the level and top it up before starting it
What do you suggest cleaning the lines with and core with ? It is second hand so has oil and crap all over it.
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
