Originally posted by KILLER-T
I got eveything bolted up and started her up and nothing so i rang up ***** and he told me the car wont run setup like that and i would need a new ecu like autronics
Err , why ?
Power FC is fully adjustable. Only difference is that it uses Airflow voltage and tps to control whereas Autronic uses map and tps to control.
Why can't you tune the Power FC ?
Cheers
Ken
Killer,
Glad we encouraged you. I don't want to be rude about that guy, cause I know lots of people use him, but he doesn't know much IMHO.
Plenty of tuners around, so give them a go. But Steve does mine and looks after my friends:D
See'ya:burnout:
Originally posted by GTS-t VSPEC
Killer,
It's a good job that you we asked you why you needed it, otherwise you would have been seriously ripped-off. If you get advice, always ask for another opinon, the forum is a great place for that:D
See'ya:burnout:
Agreed,
Killer is the TPS connected? as I cant recall seeing it in your pict's.
Damqik
'Hello I'm an agent for Ripoff's Inc.'
Ask the guy one more time if the PFC will work (don't tell him it is) then if his answer is the same tell him you got it to work and tell him what you think off his lies.
Guest KILLER-T
I have the factory nissan TPS on the ford throttle body i asked mario if he could make a bracket to mount it on and it seems to be working well. The noise you get from the plenum sounds wicked i think it must be because of the thinner alloy its made from or something like that but it sounds nice
I got a Sub-Zero plenum + fuel rail at the end of last year... Very nice, good sized Bell-Mouths... I'm running a EF Throttle body with the Ford TPS, but Glenn at C-Red took the Ford Throttle linkage off and put the standard Nissan one on... I'm running Autronics SM2 V1.94... The plenum is awesome!!!!
DAMQIK GTS-T is right about that solenoid...
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
