1995 mod r33 gtst white, manual, 103,000km tein ajustable suspension, 17 inch avs gold 5 spoke, GTR body kit, intercooler, standard airbox with K&N panel filter,apexi power fc, boost controller, hi flow turbo running 12 psi, ajustable fuel reg sard, bosch fuel pump, heavy duty clutch, apexi rev speed meter with G sensor, 3 inch exhuast with twin muffler. ABS brakes, sunroof.This car put out 233rwkw in non shoot out mode. Brand new 2 face flip sony deck, pioneer speakers and 12 inch subs. $17500
Contact Elliot 0433104794 or [email protected]
https://www.sau.com.au/forums/topic/129561-cheap-r33-gtst-233rwkw/
  • 1 month later...
