  • Replies 44
hey all....
outstanding response
bit more specific now
MUST HAVE A SUNROOF
NOT BLUE OR WHITE.......
Dosent mean your blue or white car is not going to make it, just more cars are wanted
EMAIL PICS TO [email protected]
Thanks
Ed
If possible, try not to portray that people on the wrong side of the law drive cars like ours... I know its fictional and on TV for entertainment but the Today Tonight and ACA crowd don't need anymore references to us being arrogant/dangerous/irresponsible people on the wrong side of the law.
If its on TV it must be true is the attitude of many australians!!! :rofl:
Make the good guys drive them!
That said I will definitely watch it when it eventually comes out. Any idea when that might be?
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
