I am selling the following parts to suit a gtr etc:
-Buddy club Height adj coilovers, very light alloy, excellent condition, suit 32 gtr $800 ono
-Tien HR Height and damper adj coilovers, perfect condition, no leaks, can test in car $900 ono
-Adj fuel reg, mounts to end of standard rail $150
-Mines ECU, runs good afr's $200
-Unichip, complete unit inc loom $500ono
-High mount tubular exhaust manifold, brand new $550
-33 GTR radiator air deflector, covers gap around bonnet latch $120
-RB26 air flow meters inc hks pods - $370 the pair
-32 gtr castor arms w/ aftermarket poly bushes - $100
-OS twin plate clutch, perfect condition, can be installed as is - $800
-Set of gtr rods, perfect condition - $200
-Blank RB26 Head - $500
-33 GTR Brake master cyl, good condition - $250
-32 GTR steering wheel, perfect condition - $250ono
Can supply pics for all parts.
All parts are in Melbourne, but COD etc OK.
Call 0410697349 or email [email protected] for any further details.
cheers.
https://www.sau.com.au/forums/topic/129733-lots-of-gtr-parts/
hey mate, can you send pics of the exhaust manifold to [email protected]
let me know if its not t4 flange, as im only interested if its t4 flange.
cheers simon
  • 1 month later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
