Dinner on Tuesday 15th Aug will be at Nando's Newmarket @ 7pm.
Nando's is located in the Reading Complex, which is on the corner of Enoggera and Newmarket Roads, Newmarket.
Please see below map.
Please RSVP by 3pm on Tuesday so a booking for the right number of people can be made.
Hope to see you there!
https://www.sau.com.au/forums/topic/129791-tuesday-night-dinner-15-august/
Ummmmm double breast burger with large upgrade... My tummy is full...
We missed you this everning Dave...
Good to see Dale out tho... Long time no see...
Also Jason and I had a fun drive home, with a White 180sx and a black R33 s1 decided it was import race time...
Idiots... Good to see the old feller on the bike wipe the floor with the both of them...
01010100 01101000 01101111 01110010 01110000 01101001 01100101 00100000 01110011 01100001 01111001 01110011 00100000 01100010 01101001 01101110 01100001 01110010 01111001 00100000 01101001 01110011 00100000 01100110 01110101 01101100 01101100 01100101 01100101 00100000 01110011 01101001 01101001 01101011 00100001
There is no way im gonna even take the time to figure that out...
Damn you Jason...
Just tell me....
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
