hi there , just removed the master cylinder as i was told it might need a rebuild from our brake and steering workshop ,was leaking slightly but couldnt see where ,anyway after i took it off i noticed the rear seals were all nice and dry, but noticed inbetween the front outlet and the second outlet there was a hole that had been plugged up with some black silicon and seemed to be leaking from there , could any one tell me what this hole is for as now i dont see the point of a $200 rebuild if it is only leaking out of this hole what is it for? please help somebody <<<<<the brake and steering shop told me he didnt know what to do with it great ehh so called specialists!!!
https://www.sau.com.au/forums/topic/130341-r32-brake-master-cylinder-help/
  • 4 weeks later...
i wouldnt want to be mucking around with something as crucial on your car as brakes... you can pick up a second hand one for less that 2 hundred bucks but theres nothing to say that that will go aswell... id be looking at spending the 200 bucks and not worrying about it leaking for another 10 years
yup...your an idiot if your gonna go cheap on such an important part of the car. Fully working brakes are actually rather integral to the slowing down and stopping motion when driving a car believe it or not....ha who would have thought?
If they're not sure and you dont know jack...safest option is to get it done. If it were me, which it isnt, if i had it off and it wasnt leaking i would still get it rebuilt. Ya never know.
Put a pic of the master cyl up, them we maybe able to tell you what it is . Are you sure its not the bleeder hole? Some one may have taken the bleed nipple off and then blocked it, if thats the case you will need it to bleed it when you re-install it .
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
