ouch jet-33
welcome to my world
i cracked my front bar in two places first day i got the car
haha
but man its a new 400R bar, thats a bitch
how bad is the cracks? are they like mine?
maybe you can buy some fibre fill and do it yerself
and jus put some touch up paint on it
since its silver and it isn't that noticable on silver
are you running stock height?
man you musta went over the driveway pretty hard to crack it
i went over a ramp at 40kmh and bang two cracks and other line cracks all over the ridges and cracks where the bolts and screws are
pretty fuct up
was barely movin at all, just a little lip on the side of the drive
i think it was actually the fkn support brace undeneath that the damn panel beaters decided to put in...theyve stooged me again
cos i think that rubbed on it, cos the bar didnt touch, and cos the brace didnt want to budge it draged the kit with it and cracked it
im lowered, real bad with this bar, haha, low as
ouch!
i feel for u jet.........i've been there
just one small mistake and *crack*!
damn fibreglass!! why can't they make it more flexible!!!
try Auswide in Ringwood, found their prices too be lower than other places i checked, and they did a decent job of patching a HOLE and repainting my front bar........
address:
4-5/7 Heatherdale Rd Ringwood
(03) 98702088
Time, labour, oven time, workshop time - plus the fact most are insurance jobs so they can jack the price up. I reckon just speak to a few places - whenever previously I've got stuff fixed on old cars, its generally "is this an insurance job?" say "yes" and its like almost double. Speak to 'em, if they jack you around just go elsewhere. My 2c.
Fibro kit is $30 plus a few extras you'll need. I might make a start on fixing mine this arvo.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
