hey guys i got a gmg r33 gtst serious 1 and im kinda indecisive on which rim would look best on my car heres the 2 choices.
i was thinkin about gettings 19's but are there any problems with them on a skyline etc. im after something racey, looks good and stands out wantint to put it in a show maybe in the near future.
thanks guys
sam
https://www.sau.com.au/forums/topic/130992-need-help-choosing/
  • Replies 83
Posted Images
Grey rims look awesome :D
But looks like you prefer the gold (looks at avatar :D ). As others have stated it is only your preferance that counts.
I have used 19's on my car for 4yrs and have had no problem at all, but tyres are more expensive and you do loose a little torque (inertia). Here is a pic of my car, i wouldn't go much lower as it will scrap the gaurd liners.
