I was experianceing a hollow knock noise followed by shaking of the left wheel when going fast. i took kicked my wheel and noticed a bit of movement.
Then i noticed that the rubber thing 'i think its called bushes' broken.
just wondering can anyone help me with the real name and were i can buy new ones.
And if possible what kind of $$ im goin to be expecting..
Thanks..
https://www.sau.com.au/forums/topic/131074-quick-help-needed/
best to take a picture an post it up if you want a definate answer on what the part is...there's lots of bushes an parts in there that this could be?
My guess would be the tie-rod end (where steering rack connects to wheel hub)
but could be a control arm bush, a caster rod bush, link pin bushes, ball joint?? to hard to say with a fairly vaige description.
Im gussing its the control arm bush. I was reading up and i have to get it done by a mechanic cauz i dont have some hydrolic thing to compress the bush. so ill just go there.
"Whiteline handling pack" mmmmm sounds interesting. what is it??? cauz ur persuading me to spend more money.
Thanks abcent for you reply really helped.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
