www.98
  • Replies 73
APC seem to know what they are talking about.
When we had all the troubles with Brutis they knew what the issues were and helped us. *me mumbles something about how crap mazfix is (we wen't to mazfix cause the engine in the laser is from a familia.. before anyone makes any smart arse comments)*
They told us to go a Power FC which seems to be the same advice from everyone. One day when I have money. One day!
https://www.sau.com.au/forums/topic/13112-www98/page/3/#findComment-265390
  • 4 months later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
