Yeh hi since ive turbo'd my engine rb25de i put a drift oil breather on as shown in the picture!
the as u can see the blue'ish filter there use to be a hose leading the the stock airfilter piping...
since i turbo'd my engine i had nothing to put there other then this filter.
when i give my car a bit it seems pressure is building up and forcing oil out of the filter and yeh needs to be fixed asap. can anyone tell me what i can do to fix this problem?
Thanks heaps people!
Edited by Stealthynsa
https://www.sau.com.au/forums/topic/131580-oil-problem-since-turbod/
oil coming out of that line will happen no matter what you do.
only thing you can do to stop it from going around your engine bay is to stick fit an oil catch can.
do it ASAP. the oil around your exhaust manifold coult start a fire!
its not coming from the turbo oil line... its coming from the top of the engine where the filter is...
and oil catch can? what would this do to help me, i tried pluging it up once but then the pressure built up
and spat out of my dip stick...
i didnt say anything about a turbo line.
the place where you fit the breather is meant for a pipe heading back into the intake.
air comes out of there and sometimes oil will come through your rings. this is called blow by.
do a search on catch can and you'll find something.
so if i put this catch can on there wont it also over flow?
or does it drain back into the engine? what happens if this builds up with pressure?
btw thanks for ur help dude
yeah it will fill up eventually, but at least it wont spill onto your motor.
im more worried about your dip stick blowing out. have you gotten a compression test done? this is usually a sign of worn or even damaged pistons/rings. get it checked out asap.
the catch can doesnt fill up with pressure, the air vents back out to either your intake or atmo.
how much is a compression test/ where would i go... and what do they do to test it, am i able to test it myself?
whats a atmo?
there is a fair bit of oil that comes out... it never happened untill turbo'd it.
and also when i give it a bit of a rev burnt smoke comes out of the filter would that be normal im guessing its burnt oil?
The oil wont overflow, the blow by will then be caught inside the catchcan instead of spraying all over the place inside your engine bay, As security said its actually meant for a pipe to go back into the intake
so by u saying a pipe goin back to my intake... u mean the 2.5" piping to the throttle body?
you could do it yourself, but it'll be hard to crank your motor while reading compression, just drop it off at a mechanic and ask for a compression test and a leak-down test. it shouldnt cost too much, probably the same amount as buying a compression tester.
atmo = atmosphere.
atmo = atmosphere.
where is the atmo?
thats your inlet pipe.
intake is your air filter pipe. so it needs to lead to your turbo.
a catch can will seperate the oil from the air before it hits your engine though. thats its purpose.
ok now u have lost me sorry about this...
um i put 1 of the tubes of the catch can onto the part where its leaking ontop of the engine.
and ur saying i put the other tubing into the atmo or the intake? if i put it into the intake wont it go back throung somewhere its not suppose to?
read:
http://www.skylinesaustralia.com/forums/in...%20can&st=0
this is a goodie:
http://www.skylinesaustralia.com/forums/in...20can&st=20
on the side of ur engine u have a oil return line from a step down at the fron of the rocket cover down the the bottom of i the engine... i T peice my turbo's oil return line in there... would this be why ther oil is coming up and spurting out? im saying would the oil+pressure from the turbo's oil return go back up through the oil return from the head and therefore come out my airfilter?
if you've T'd it into a pipe you KNOW to be an oil return pipe it shouldnt be a problem.
i know its an oil return from the head but what im saying since there is pressure coming from the turbo oil return would it head back up the oil return from the head causing the head to overflow and rid the oil out of my air filter?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
