hmm sound intresting im looking at buying one but not quite sure wat the go is
As a first approximation Rpm to reach full boost is just about inversely proportional to a/r.
So if 0.84 = 5,200 Rpm
0.68 would be close to (0.68/0.84 x 5200) = 4,200 Rpm.
Of course exhaust back pressure will be a bit higher with the smaller housing, so it will make less power at the same boost, but it will probably not be that much slower on the road, and a hell of lot easier to drive.
Go back to where you bought the turbo, and ask them what they can get for you. There are a number of housings available, 0.7 single entry, or 0.68 split pulse may be about the right sort of numbers to ask for. These are the next step down from the 0.81 single entry and 0.84 split pulse that you already have.
https://www.sau.com.au/forums/topic/131666-to4z/page/2/#findComment-2446267
Great result mate and nice turbo choice...!
has anyone lined up the HKS version and garrett version for performance and heat produced etc...on the same engine?
how would the .68 housing go on an RB26? ie what rmp would it come on at and what range of power figures could you expect?
https://www.sau.com.au/forums/topic/131666-to4z/page/2/#findComment-2451225
    • Well, i've been told it's going to be in Poland around october - november. It should set off by the end of this month. Waiting for it to arrive is the easy part, searching for the right car, wake up in the middle of the night to see the photos and decide whether to bid or not - that was difficult
    • Thanks mate, i'll keep that in mind. Not sure though if the black carpet will fit grey interior. I'd prefer original Stagea set but if i fail to find one in another few weeks, i will probably come back to you. p.s. - is this original, licensed Nismo product?
    • I'm a strong believer that old sports cars should be reserved as weekend cars and owned by mechanically inclined people. The risk-reward ratio is only acceptable under those conditions.
    • @Stringycheese hopefully this is helpful. 🤣
    • Welcome Marek! When does it arrive? Waiting sucks.
