hey guys im picking up a bride brix I drivers seat tonight but it comes with a genuine bride LOW mount rail.. suits R32/R33/A31.
any tall guys wana swap for their standard height rail to suit a bride brix I for mine? dont mind if its not a genuine either as long as it suits R32 GTR & standard height! i think im going to be sitting to low lol
sydney only tho :P
thanks! pm for interest or post here
https://www.sau.com.au/forums/topic/131698-swap-genuine-bride-low-mount-rail/
Hey,
I'm 5'7" and it fits me fine, about 15cm shorter than stock but u can still encline the seat to see.
My line of sight would be 10-15cm above dash height, plenty
BTW ( its a BNR32 GTR too) :D
I have a low mounted brix,
its pretty low and i am 174cm,
seem low at first,
but got used to it,
not too bad, u can see almost everything,
tho u need to tilt the steering wheel down,
else u gona be like Harley Dadvidson Badboy rider.
i dont know which one is the serial number so here is the pic of the bottom rail.. i tried it jus then nd yeah id prefer to have a normal rail so its up for swap any time :(
located west suburbs syd
*edit* serial number is: N103SL
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
