Hi everyone!
I think the title said it all...
For all those in adelaide, hopefully you've checked out the SA section of the forum and read about the SAU cruise thats happening today...
I'll be heading into town for it today and was just wondering how many other stageas will be there...
Looking forward to meeting some of you (if not today, maybe another time? should do a stagea-only cruise someday :rolleyes:).
I'm fairly sure Tangles is coming.
It would be great if you show me your car there as i wanna change from the R34 to a stagea
Ok, mine's the white S2 - i'm pretty sure it'll be the only one there. Haven't seen any S2's in adelaide yet, though I'm sure there are a few.
Interesting you want to change to a stagea. IMO the interior of the stagea is slightly better.
I was deciding between an r34 4door and a stagea s2 back in march and finally went with the stagea.
For me it was the uniqueness of the stagea, and the nicer interior, and I think the whole sports wagon thing is cool.
It was all a matter of practicality and the stagea has loads of boot space which we've used many times now. I'm very glad with our decision.
The r34 would've been a lot faster, due to ~200kg less weight but the stagea has AWD to compensate and still has lots of power potential (depending what you want the car for) and AWD is great for driving in the wet. Just gives more confidence.
More pics from the actual cruise on this thread : http://www.skylinesaustralia.com/forums/in...8093&st=200 page 10 onwards................
Sorry - only took a few of the Stags........ my little lad was SOOOOO wanting to climb the big Rocking Horse, "play with me Dadda, play with me" - how can you resist that? :laugh:
Was great to meet you Steve (Pixl8r) - nice and clean S2; pity about that front fender scratch hey! Im guessing you never saw the crack in my rear bar then?
Alex, cheers; you're right, as always, GTT rims on a Stagea without centrecaps looks HORN (imo - others agreed on the day tho)
Apologies for not getting better pics - its hard to watch the youngun, chat to likeminded ppl (great to meet the ledgendary Cubes etc), and take photos too. Top arvo tho, always a pleasure to drive thru the Adelaide Hills...... hell, I even felt my 'chassis' for the first time, LOL :P
Sorry - only took a few of the Stags........ my little lad was SOOOOO wanting to climb the big Rocking Horse, "play with me Dadda, play with me" - how can you resist that? ;)
Yeah i saw that scratch on the front when i got to the Gold Coast to pick the car up. The guy at the dealer's told me over the phone "ha if you want photos of scratches i'd hafta make some scratches first'...and then i get there and there's like 6 or 7 noticeable scratches. The interior was spotless so it wasn't all bad...and the outside isn't too bad overall. But just another big lesson never to trust a car dealer. I never got to see the auction papers either - even though I asked for them. They said they dont keep them (yeah right - happens to be a legal requirement that they do) - so all I have is several mechanic's word that the km's do appear genuine. And it is auction grade 4.
I thought about GTT rims before - and seeing them on your car really helped. For the money you cant beat them. I've seen some on ebay before, might keep on looking. Not in a hurry - just if i see a bargain sometime...ideally I'd want 18's but i'll never be able to afford a good set of those.
I got plenty of photos. I loved the photos of all the skylines in one big line driving through the adelaide hills...yeah!!
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
