Hey guys trying to get a silvertop motor going here and have a very annoying prob.
I got the motor off someone and it had no compression. So I get it home and rip the head off expecting to see scored bores the rings lands melted etc. Upon inspection and taking the bottom end apart it was completely fine.
So then I check the head out, turn both the inlet and exhaust over and all the valves etc are moving fine.
So I put it back together but when cranking it over it the starter motor does not strain what so ever like there is no compression.
So I thought the timing may have been out but its all good, cams on TDC and bottom end on TDC too.
But still just turns over way too easy, I am suspect on either the inlet or exhaust no completely sealing off which may cause it.
About to go out and get a comp tester, but I am 90% sure it will show nothing.
Any suggestion what could cause this?
I have no exhaust many on, but that shouldnt matter.
https://www.sau.com.au/forums/topic/131873-rb20-issue-suggestions-welcome/
Are the spark plugs in the motor? Also piston rings could look ok, but not seal the combustion chamber. The valves may move ok, but are the seats ok? And if you took the motor apart and re-assembled it with the same head gasket, any chances of making compression are greatly reduced.
Spark plugs in yeah, rings are ok as I took the head off and put it onto a known good bottom end.
Brand new head gasket too. I suspect on the seats for now, taking the head off now to check it out again.
Tested with a comp gauge and it registered 0 accross all 6. Its torqued down to spec too.
stupid question, but you said the starter felt like it wasn't using much effort to turn the engine over... i take it you're doing the compression test by kicking the engine over using the starter with the coilpacks off?
have you checked that the starter is actually engaging and turning the engine over? I.e. are the belts at the front of the engine turning when you kick it over?
like i said, sounds simple, something worth double-checking though...
yeah found out what it was, the valves were bent.
At first glance it appears to be fine but when looking under each valve from the side they are slightly bent.
I suspect it was over reved, going to need new valves.
Edited by James_03
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
