It all depends on what else is done to the car, and what you use the car for.
Stored flywheel inertia and some clutch slip is the only way to get ANY manual transmission car moving from complete standstill without stalling. But so very much depends on available engine torque, vehicle weight, and overall gear reduction in first gear.
Once you are moving, the flywheel is nothing but extra weight and extra inertia you no longer need. A circuit race car is not normally doing constant starts, so a very light flywheel is usually an advantage.
A drag race car with excellent traction will launch harder with a heavy flywheel, but that same flywheel may slow down the rate of acceleration once it has launched.
Turbo engines are special, because they usually have minimal torque when off boost, particularly when starting off. If your engine is laggy and has a fairly high boost threshold, a light flywheel is going to make starting off even more difficult than it already is.
If you drive the car every day in heavy traffic, a very light flyweel is quite likely going to be a real pain in the arse, especially with a highly modified turbo engine.
In flat places like Melbourne, it will not be quite so bad as in hilly Sydney. Starting off facing up hills needs plenty of flywheel.
Its 'almost' a little contradictory but not quite. The initial take off may require a few more rev's but once past this the car will (as I noticed) rev up quicker and feel as if it actually has a little more off boost acceleration. I didn't notice the more rev's requirement from a standing start under normal driving conditions, it was only when launching the car.
As I think I said earlier I found the gutless rb20 easier to launch with the lightened flywheel, it did require more rev's other wise it would bog but launching at the correct rpm it felt as if it was easier to control any wheel spin that occured and it simply got off the line cleaner.
An R32 GTS4.... I would most definitely stick with the stock flywheel, they require an almost redline launch not to prevent bog, in this circumstance a lightened flywheel would cause launching problems as a result possibly slower 0-100 and 1/4 times. As we all know the faster we can get up to speed earlier the quicker our 1/4 will be. The old Auto VLT's are a prime example of this running mid 10's with only ~300rwkw.
I'm with Cubes on this one, and is the exact reason I'm going for a lightened flywheel when I change my clutch in the next few months hopefully. The RB20 is a dog for me driving into/out of the city every morning, stop start conditions, and off boost acceleration is very poor.
Also of note, what I picked up a few weeks back. The weight of a flywheel is not as important as the distance that weight is from the centre. I believe it is a radius ® squared relationship. Hence a 10kg flywheel with a large part of it's weight on the extremities will be a lot harder to turn than a 10kg flywheel with most of its weight near the centre. This is why you see standard flywheels being lightened with holes/removal of steel as near the extremities as you can get. This has big benefits even though it may only lighten the flywheel by a few kg's.
Fixxxer :D
I have a 4.5kg flywheel in my car.
Positives:
- engine revs easier
- revs drop really quickly
- less engine braking
Negatives:
- revs drop quickly between gear changes
- need revs to get the car off the line
- meh..
I like it.
  • 4 weeks later...
Slightly cheaper price for what looks like the same item here;
http://www.tweakit.net/shop/index.php?cPath=326_367_374
Does anyone know the weight of the RB25DET standard flywheel?
Also Aluminium @ 5.0kg for around $520 or Chrome-Moly @ 5.5kg for $100 less???
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
