Just Drop To Say Hi To All Members
hi everyone
i am from japan chiba and been study in australia around 5 year, miss australia so muchie
and now back to japan and work as a trading salesman
and i love motorsports
my pride and joy is a Z33 350z,
and i used to have a ECR33 in austraia
anyway just drop to say hi to everyone, anyone need any thing help in japan here, just message me
please forgive my bad english
:P
https://www.sau.com.au/forums/topic/132812-just-drop-to-say-hi-to-all-members/
Hi Sam,
Welcome to our little forum. It's always nice to see more japan members. I will be over in Chiba for a little bit in november. I've been there and stayed there a number of times. Nice area. Go the Port City! :)
Rezz* i bet you also in japan right now? anyway nice to meet you guys.....
No, right now I'm in Perth in WA, but I'll be in Osaka early in November. I'll have to meet up with you at the Tokyo Auto Salon maybe?
Hi Sam, Me and my Wife are going to be in Japan Early Oct. Staying with her parents in Toshima, Kita-ku.
should pick us up for a cruise into Tokyo in your 350 *drool*.....joke
getting excited now. can't wait to go over...
Beer Baron*
nice to meet you 2, i am sure i will be enjoy this sections
if you heading in japan soon, if have time let meet up and just have a beer or something....yeah..
Hai! I am always interested in a beeru and a bowl of ramen. or should that be a ramen and a bowl of beer? :ninja: We might be able to make some time when I get there.
Yes, I will be in Chiba for a few days from 3rd November.
Then heading to Osaka/Kyoto which will enable a little catch up with Rezz. :dry:
Rezz: icic you are in perth right now....but sounds good lets have a meet when you heading to tokyo we should meet in auto salon
Beer Baron: no problems...lets meet in japan
if anyone can make up a schedule...
NYL83R* yeah why not, just keep me update or contact me here
from now on i will be in here always...SO waRm.............a nice family
here is my PRIDE and joy
most work done by IMPUL and AMUSE...since amuse is around chiba
IMPUL 500Z
full stain manifold
IMPUL X OHLINS damper
IMPUL 500Z fornt spoiler
IMPUL Full CARBON GT wing
IMPUL hi power control unit ECU noraml 6600RPM MAX from STandard mine one up to 7000RPM
NISMO gauge cluster
NISMO oil cooler
NISMO PADS
AMUSE R1 titanium muffler to MID pipe
central 20 CARBON bonnect
RAYS TE37 19inch with RE01R RUBBER
ect...... ;)
Edited by 350z33
Thats one great looking Z33 you have there Sam ;)
Welcome to SAU
I will be in Chiba in January and will be meeting with Rezz for Tokyo Autosalon, perhaps you could come along :)
Nick
hi nick...nice to meet you
yeah we wll have a meet for sure...
looking forward to..
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
