I there any company's that are on board with SAU
to give cheap Frieghting Interstate
Because there is alot of parts going all over the place every day
if there isnt Is there a chance to get a company on board
It would be good for everyone
(Just a thought)
https://www.sau.com.au/forums/topic/133126-shipment-frighting-and-couriers/
There is no freight company onboard with SAU.
Why do we need one?
Has someone offered?
I couldnt see it as a requirement, we have enough sponsors/traders as it is.
www.yellowpages.com.au
Let your fingers do the walking if your looking for someone yourself to ship stuff so anything that Aust Post cant handle
If im ever to start my own business i will do this for sau
cause there is that much stuff being sold and transported its not funny
company would make a mint
anyway does anyone know of a good cheap frieghting company i can use
for interstate stuff
so u expect a free site to organise a better price for shipping and stuff (or some form of an account) and u dont even give anything back in return?
if ur a business a frieght company will allow u 2 set up ur account. but i guess thats not the case here
if ur buying something from interstate for urself, expect to pay for frieght like everyone else.
also cheaper doesnt always mean quality transport either.
imho, use aust post. always the cheapest
Do you guys understand business at all?
all im saying is a company could easily start up and have enough work
through this site to not even worry about contracting.
and thats probably only if half the people on here went through them to frieght parts
it could work the same sort of way as people selling parts or group buys
a certain amount of orders from lets say melb to bris (customers on sau)
ship maybe twice a week or something like that
hence cheaper price
no account has to be set up just a bit of organisation
anyway forget it i will get my mate to ship my stuff for me
Just used VICFAST
to ship a IMB PC Tower Server to QLD and it cost $62 for 25Kg -77cmx55cmx30cm (+ $1500 Ins for $60)
Seemed to be good value after looking around and client was happy to pay it.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
