Called around Repco, Super cheap auto and Bruson and none have Bendix Ultimates...
They do have at Burson for $59 front and back Bendix GCT.
Are these any good? I dont plan to go tracks just for normal street driving.
Also is machining the disks a must or can I skip that part?
Cheers.
https://www.sau.com.au/forums/topic/133139-need-brake-pads/
Cheers.
Generally you only machine the discs if they have noticeable wear on them (use your fingernail from the edge, if there is more than a 1 or 2mm gap, they certainly need machining, or possible replacement.).
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2466883
Can any mechanic workshop machine the disks for a skyline or must i go to some special one?
Also how much is the process?
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2466962
i recommend getting better brake pads matey... as you all know we all spend how much money to make our cars go faster, but sometimes very little on stopping. its a performance car, and better brakes mite save your life or someone elses life.. just my 2c >_<
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2466981
Well the car is stock and wont be seeing the track any time soon... after all they are just brake pads...
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2466999
Don't use greenstuff try the ferodo pads T2000 better for performance driving plus you can get the pads and discs macnined at Race Brakes Sydney.
The disc rotors may also need machining because often the rotor will wear on uneven or on a taper so machining will fix that and make the surface flat for the pads to bed in properly.
Edited by PMATT
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2467100
yeah thats pretty cheap, we do em for $26 per rotor, but add to that half our labour if your not getting pads done at the same time.
through my work you get Ferodo Excel pads (bendix advance equivelant) with rotors machined, all fitted an done for $201
just to give you a reference
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2475512
iam running the bedix ceramic pads at the moment, lacking in the performance area but absolutely no brake dust. The last pads i had were the bedix metal kings or something along those lines with heavy metal compound, i found these very very good for stopping but shit load of brake dust and also being a metal pad they will wear and tear your disk alot quiker
Ryan
https://www.sau.com.au/forums/topic/133139-need-brake-pads/#findComment-2476555
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
