Gb: R32, R33, R34 Skyline Carbon Fibre And Fibreglass Bits
  • Replies 272
Rflirty4 added to the list... just awaiting confirmation of stock first.
All the others in Order #2; your stuff is en-route now, sorry for the delay.
Well he said he's just waiting for a moment to get to the post office over there - it only takes a few days after that and I'll be sending everyone's stuff express once it's here!
OK I got an answer for the CF boot lid... you can get these in the following "colours":
Black CF (what we usually see in AUS)
Silver CF
Blue CF
Price I've been told is approximately $1k + freight... they are as per the photos posted on page 1. Obviously a few things will need to be transferred over (stop light, locks, latches etc)
Personally, I wouldn't bother unless you're made of gold.
Silver CF
Blue CF
any idea on freight cost?????? cause i really dont mind paying $1000 for the boot lid itself (as there is only one guy in australia that i have had an answer back on and said he can do it but he wants up front payment before making it and sound a bit dodgy eg. no pick up and bank deposit only even though he is in sydney and close to me!!!!)
maybe if more ppl want them we can split the freight costs?
and by the way im after black cf
thanks
Justin
Cost of freight will depend on the way we send it... obviously it will need to be packed very well; insured and tracked - these three items don't come cheap; add on more if you want it in a hurry too.
I will dummy up some numbers :P
thanks
i would appreciate that heaps, if other ppl are interested in these boot lids for r34 please voice your interests now and we maybe able to save on the shipping cost...
by the way im not in a huge rush so if i can save on the cost of freight by sending it economy, by boat i dont mind
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :) (I'm small, so lay off)
I'd estimate that by sea; you'd be looking at an extra $100-$150 in freight... those in Sydney can then make the effort to come collect it from me as I really cannot be bothered to lug around a boot lid :dry: (I'm small, so lay off)
mate that price of $1000+$100-$150 freight is fine. can you go ahead and order a black cf one for me please. just let me know when you need payment we can meet up and i can pay you in person. and pick up is not a problem.
also is there any chance of getting the boot lid made without the key barrell hole and the middle brake light hole? if so i would appreciate that but if not it doesnt really worry me.
thanks
Justin
0425291404
Justin; I'm not going to promise you anything yet - I will have to get in contact with this guy and ask for confirmation. I don't want to promise something I can't deliver that's all.
If he's all good with it then yeah, we'll go ahead with it ;)
If he's all good with it then yeah, we'll go ahead with it :laugh:
satanic
no problem mate just let me know when confirm. i appreciate your help.
thanks
Justin
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
