Group Buy # 2 Arospeed Adjustable Cam Gears
  • Replies 223
Posted Images
Guys it will take about 12-16days.
Gears will be ordered 2 morrow.
Ill send all members that have paid PM'S.
Thanks for another successfull GB, there might be a 3rd depending if im in a good mood.
But please understand i do this because, members ask me and i dont mind helping our members out.
Anyone know how much it costs in terms of labour hours it costs to install one of these gears along with a new timing belt?
Is it easy to do it yourself?
Edited by Edge
Expect around 220-320 depending on if there is enough slack in the timing belt for the tuner to slip off the old cam gears and pop on the new ones. Thats fitting and dyno tuning time
Edited by Cillham
have these been ordered? just wondering.
I'm sure everything is fine..
Our gears will arrive when they arrive, and that's all we can do.. Just sit back, relax, and wait.. :)
I still haven't recieved any PMs other than the account details..
I'll keep watching this thread for any updates.. :spank:
Sorry guy's for no reply's but my ADSL service is down and im using a mates dial up (slow as)
Any up is a list of all that paid, what i need all you to do is forward me a PM with the choice of colour for your gears (blue or red) and your full name and delivery address.
Your asking why am i asking about colour and addresses, ive got this info in my PM and have ordered all clours requested, but if i loose this info ill atleast have it again if you PM again.
The Gears were ordered on the 16/10/06 supplier said funds cleared 19/10 so we shall see the gears soon.
1)NV N01 * IN FOR A PAIR PAID
2)MUCK * IN FOR 1 GEAR PAID
3)Lazy-Bastard * IN FOR 1 GEAR PAID
4)fredzz32 * IN FOR A PAIR PAID
5)robbo33 * IN FOR 1 GEAR PAID
6)Cillham * IN FOR A PAIR PAID
7)Kinell * IN FOR A PAIR PAID
8)XZLA.8 * IN FOR 1 GEAR PAID
9)frother * IN FOR A PAIR PAID
10)DJRIFT *IN FOR A PAIR PAID
11)jnr32 *IN FOR 4 PAIRS PAID
12)dead32 *IN FOR A PAIR PAID
13)Frank rb25 zed *IN 3 GEARS PAID
14)kjb_r33 * IN FOR A PAIR PAID
15)DRKSKY32 *IN FOR A PAIR PAID
16)jeffworld2 *IN FOR A PAIR PAID
17)JaFF * IN FOR 1 GEAR PAID
18)RANDY *IN FOR 1 GEAR PAID
19)stR33ter *IN FOR 1 GEAR PAID
20)woolls *IN FOR 1 GEAR PAID
21)phatboi2010 *IN FOR A 3 GEARS PAID
22)rza1 *IN FOR A PAIR PAID
23)Edge *IN FOR 1 GEAR PAID
24)Turbz_13 *IN FOR A PAIR PAID
25)aquariuz6 *IN FOR 1 GEAR PAID
26)SXY *IN FOR A PAIR PAID
27)ls1ben *IN FOR 1 GEAR PAID
28)Lionel s *IN FOR A PAIR PAID
29)wrrr *IN FOR A PAIR PAID
30)skiddy *IN FOR A PAIR PAID
31)jonnyo *IN FOR A PAIR PAID
32)mojave15 *IN FOR A PAIR PAID
33)R3LOAD *IN FOR A PAIR PAID
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
