OK guys,
I know this has been done on other forums, so lets get it going here.
It is a great way for us all to get an idea of what mods create what power on what cars. Only list performance/power related mods as that is what this thread is all about.
Here is mine.....
CAR:
R32 GTR
MODS:
Trust Airinx Filter Kit
Trust MX front pipes (2 x 75mm into 1 x 80mm)
Hi Flow 3"(80mm) Cat
Buddy Club Racing Spec III Exhaust (89.1mm through)
HKS Slide Cam Pulleys (cam gears) - IN and EX
Custom Bleed Valve
1.1 Bar Boost
DYNO RESULT:
240 Rear Wheel Kilowatts on RacePace Dyno Dynamics Dyno
QUARTER MILE TIME:
11.573 @ 117.89 mph (1.712 sec sixty foot)
Shaun.
https://www.sau.com.au/forums/topic/1335-power-output-and-14-mile-times/
  • Replies 45
R31 Nissan pintara station wagon
SPECS -
rb20det conversion
Full 3inch ****** (not going to give them any advertisement) Exhaust Inc trust style Dump pipe
Supra 7m front mount
****** Pod filter
Basic Turbo Smart bleed valve/ Apexi Dual sbc
Gts-x Front brakes and calipers
Laurel Wheels 15"
Standard rear suspension and diff (read - Sloppy and single spinner)
Performance -
13.8 @ 100 mph (12psi)
170 rwhp (9psi)
My last 1/4 time & rwkw fig's are in my sig' :)
The car has one or two mod's.
It was run on Falken 255/40/17's with 38psi tyre pressure.
I'll get around to taking it back to AIR for some new times soon.
Originally posted by BOOSTMEISTER
13.8
You have got to be kidding right:uh-huh: :uh-huh: :uh-huh:
I am sorry but is that possible????
Awesome effort if thats what you did....I must be a completely useless driver to only better that by .1 with 100hp more than you + I have a 85% locked diff?
it was on 12psi rather then 9 as it was dynoed on so probably had closer to 190 hp at the wheels and less boost bleeding.
It was done at the kwinana motorplex in perth after an international meet and the track was rather sticky. With minimal traction loss in 2nd and only a bit in 1st.
I have a timeslip though i dont have a scanner, it is real. Also the pintara may be slightly lighter then your car and have better diff ratio (read : 4.11)
13.8 with a RB20DET running an open wheeler and 12psi.
hrmm..
When i was running 12.5 PSI with fuel at around 12.1-12.5:1 (no over fueling) I made 152rwkw. Which is almost 204HP at the rears.
She didn't feel like a 13.8 sec car then and even now she doesn't with a FMIC and almost 1 bar of boost.
If I remember correctly I think the R32 GTS-T has a 4.3:1 diff ratio or is it 4.1 also?!?! I'm pretty sure its 4.3 btw.
i.e 50-55km's in first & approx 90-95 in second.
The R32 GTS-T Weighs around 1300kg's.
The Pintara wagon would weigh probably the same if not more I would think.
Before I had the FMIC fitted I noticed that it was easier to control wheel spin through first as it didn't kick as hard even on stock boost.
For example on stock boost with 225' 50's on the rear without the fmic the rear's would not spin now with the fmic boost kicks and wheel spins in first. On high boost there is no way i can put my foot flat. Taking off and holding it just past 1/4 throttle will cause the 225's with 29psi pressure to spin and squeel. Once it starts to spin there's almost no way that I can stop it, I usually short shift which causes it to spin in second quite a bit but it seems to pick up a bit better then stuffing around in first trying to get traction. And thats with LSD.. Good luck with an open wheeler.
Got a bit off topic didn't I.
Guest white180
hey guys :) i know i dont have a skyline but i thought id add my bit anyway : 1992 180sx
sr20det
5 speed
mods : full 3 inch exhaust turbo to tip kakimoto cat back front bit is a job done by a guy in bently full stainless dump pipe is a bit of 3 inch with a bit of an extra bit welded on to cover wastegate pipe
: bilstein front shocks and springs (read:stiff as ever) rear i dunno what they are but they are matching the front as far as height goes but arnt nearly as stiff
: pod airfilter k and n usual S***
: 14 psi by way of either ebc or turbosmart crappy little bleed valve but i was borroing the ebc from rb20lagwagon and he needs it so yeah u get that :)
: 16 inch volk racing wheels 16x6 front (205/60r16) 16x7 rear (225/55r16)
performance : before boost and front pipe on exhaust ie no dump pipe and no bleed valve or ebc my fastest 1/4 was 14.2 no dyno runs at that point
: after ebc and boost i have achieved 179.3 bhp@ wheels and it goes a hell of alot faster now too :D no run at the motorplex cause its shut down for the winter :) will let u know how i progress
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
