Item: 1997 Mitsubishi Lancer Coupe.
Specs:
Engine:
4G15 1.5L RV SOHC 2001 model engine.
Internals:
7.5:1 Forged Pistons
R.P.W Shot peened turbo rods with 8mm ARP rod bolts
O-ringed block
ACL competition composite head gasket
Harrop Engineering Head studs with ARP nuts and washers
Mild Head Porting
Induction:
Garret t28 roller bearing turbo
2.5" Silver powder coated piping
Custom made stainless steel exhaust manifold
RPW 55mm Throttle Body
Turbosmart Type 2 BOV
Drift Pod Filter
Ignition/Fuel:
Microtech LT-8 - with carbon fibre faced hand controller
NGK iridium plugs nad NGK leads
Driveline:
Daikin Exedy fully sprung ceramic 5puck button clutch
1200lbs Pressure plate
Standard Lancer 5-speed gearbox
Fuel System:
AC Delco high volume lift pump
Bosch 033 400hp inline fuel pump
WRX Sti Injectors
Malpassi Rising Rate Fuel Reg.
Exhaust:
3" Mandrel bent exhaust including 3" dump
4" Magnaflow racecore muffler
Interior:
Autometer Sport Comp 5" Monster Tacho w/shift light (silver faced)
Autometer Pro-comp Water Temp, Oil Pressure, Oil Temp, A/F and Boost Gauges w/autometer cups
Turbosmart in cabin boost controller
Fully Adjustable Turbo Timer
Momo Gear Knob
Autotechnica Steering wheel
I.C.E:
Pioneer cd/mp3 Player
JL Audio 6x9s
Pioneer 5 1/4" components
Boss 600W 4 channel amp
Wheels/Tyres:
17x7.5" BSA 239 Chrome Rims
Hankook Ventus Sport 205/40 Tyres (80-90% tread)
Suspension:
Standard Lancer Struts
50mm Lowered King Springs
Exterior:
Green Metallic Paint
EVO VI Rear Wing
Securtity:
Central Locking
Hornet Alarm
Reason for Selling: Time to upgrade.
Price and Payment Conditions: 18,000 ono (may consider swap for similar turbo car)
Extra Info:
Conservative tune netted 200hp atw on 15psi (motor capable of 20+psi), with approx 3 times the torque of factory specs.
The engine has just been built and run in (approx 2000km since rebuild) including:
Forges, Rods, New timing belt, new headgasket and new big end bearings.
All receipts for work done will be included in the sale. Will also include a previous dyno plot.
Car is serviced every 3000km.
It will also be dyno tuned again before final sale.
Car is now setup to run NOS and can be ran on C16 race fuel
Pictures: Will provide on request to serious buyers.
Contact Details:
PM or contact Andy on 0408362032
https://www.sau.com.au/forums/topic/134608-turbo-ce-lancer/
will trade for and r32 gtr with soem work or and r33 gtst with soem work must be manual (im willing tod rive in order to swap)
pics can be seen here
http://www.boostcruising.com/forums/index....howtopic=160562
https://www.sau.com.au/forums/topic/134608-turbo-ce-lancer/#findComment-2536713
already had a 32gtr owner ask for a swap wasnt willign to drive to brisbane though at that stage woudl be willign to now though. have over 20k of receipts for this thing it will eb close to pulling 200kw atw next dyno session so really im sure plenty of people would be inetrested..looking at a swap for any amnual turbo'd car now...only reason i wanna swap is i've lost my license 3 times in this so far..all work has been done since i had the car so i knwo the whole history. will also coem with stock exhaust and rims.
Edited by zorb_rules
https://www.sau.com.au/forums/topic/134608-turbo-ce-lancer/#findComment-2584449
Not really much just ya basic mods would suyffice im happy to do most of the work on a new car myself..just looking for basic work maybe cooler, zorst rims,avc-r etc.. Dont want something all out.
Heres some pics
https://www.sau.com.au/forums/topic/134608-turbo-ce-lancer/#findComment-2601966
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
