This Tech Article is more a primer to give more information of the workings of a RB20DET (possibly more RB motors) and the two common mods used to improve upon it's design to sustain higher boost levels without leaking. I've included links to the Tech articles covering these mods in more detail.
Background:
A BOV acts to release boost pressure between the turbo and throttle body when the throttle plate is shut. This is good for two reasons:
1.) With the pressure released the turbo will continue to spin freely = better transitional boost response (quick spool btw gear changes)
2.) The pressurized air would otherwise hit the closed throttle plate and like an ocean wave, reverse course making it’s way back to the compressor causing it to abruptly slow, possibly causing damage to the wheel.
The 1G BOV while infinitely better than the crappy plastic 2G valves, is still an OEM piece that was never intended to boost much above stock levels (13psi) and will leak at higher boost levels.
It is important to first see how a BOV works to figure out how to improve upon it.
The below pic (minus the air fittings on the mounting flange) are of a 1G BOV. The “top hat” section of the BOV contains a diaphragm and spring which is used to raise/lower a valve at the bottom based on air pressure on either side of the diaphragm combined with the spring tension. The Blue lines represent airflow from the UIP and the Red line airflow from the behind the throttle plate.
The BOV in stock form uses both air pressures to operate the BOV. When under boost (throttle plate open), the Red and Blue pressures are equal and the BOV’s valve will remain closed based solely on the top hat's internal spring pressure (well until too much boost force on the valve itself overcomes the springs tension and pushes it open).
When the throttle closes (btw gear shifts when you let off the gas pedal), the air pressure in the UIP remains positive (Blue), but the air pressure behind the throttle plate goes to negative (Red). This is what helps the BOV to “quick release” as you have complementary forces (pull=Red /push=Blue) at work to open the valve.
This is all good at OEM boost levels, but once you turn the boost up, the pressure inside the UIP can force the BOV valve itself to unseat (blow it open), much like what happens to an upgraded 38mm wastegate flapper if the actuator is not strong enough.
When this happens, you are loosing boost pressure, which the turbo will have to work harder (faster RPMs, more heat, less efficient) to maintain. If you are running 18psi at the intake and you are loosing 2psi from the BOV, your turbo is actually running at 20psi (well more due to pressure drop across the IC/Piping but that’s fodder for another tech article :D )
Dodge Garage Mod?
The Dodge Garage mod seeks to block the Blue line (UIP Pressure) so that only the Red line (Intake pressure/Vacuum) influences the BOV operation. So now instead of equal pressures above/below the BOV diaphragm under boost, only the top section (Red) from the intake is being fed, so you have additional downward pressure on the BOV valve equal to the boost pressure you are running. More pressure = more boost can be run before the spring/valve is overrun.
To do this, this mod involves "plugging" the inlet on the bottom of the BOV flange (JB Weld) that fed the underside of the diaphram with air pressure, and drilling a hole in the original passageway to relieve any pressure from the underside of the BOV diaphram.
I took this a step further and drilled a second hole on the opposite side the original boost feed and again in the flange to give me the the option to have "quick release" if I ever wanted it (which I haven't). Connecting the two new air tubes will give me OEM BOV operation.
Crushing:
"Crushing" the BOV just means sticking the piece in a vice and pressing the top had down causing the internal spring to shorten and increase pressure on the BOV valve.
Warning, crushing too much will prevent the BOV from opening enough/at all and will cause boost surge. I crush mine so the boost nipple is flush with the middle tier of the top hat (as far as it will go without bending the nipple) and holds well to 25psi :wub:
Combining both these mods will elevate the boost threshold even further :)
any additional info is welcomed as i still consider myself new to RB motors
the problem with the mod you have writen about is that it makes the car run leaner, which isn't safe. instead of just recirculating the air it is getting more air into the system that isn't being measured by the afm. so if you have an aftermarket ecu and the car is tuned to be right on the money DO NOT DO THIS MOD!
a better way to do it is to use a big drill bit to counter sink a hole then screw a screw into the hole. this seels off the recirculation hole, and doesn't introduce any new air into the system.
So the above mod is to reduce the chances of boost leak at higher levels of boost, right? Squashing the hat down to put more pressure on the spring, and relocating the recirculation hole.
And mad082's link shows how to block just the recirculation hole to retain a bit of pressure and theoretically make the turbo not work as hard.
So can I ask: What is the recirculation hole there for in the first place? What benefit (relilability?) did Nissan/Mitsubishi have in mind when they designed it?
honestly i didnt mess with drilling and capping... in the past i have only used the crush-mod. So read and heed what mad082 has to say thanks for the feedback on this.
ill look into the other mod more in depth..... i have access to alot of the jap shops out here so ill check around.
i have a theory on the recirculation hole. they aren't just on skylines. i did a cooler install on a my99 wrx and it had the same bov, and i have seen them on other cars too.
my theory is that at full noise the compressor has to work harder (spin faster) to keep up the boost at the set level. this may sound like a bad thing but it isn't that bad. WHY? because since the compressor has to work harder, the exhaust wheel has to spin faster. this allows more air to pass out through the exhaust wheel, and less out of the wastegate.
another positive of the hole is that it is recirculating cold air. the air coming out of the hole has just been cooled by the intercooler. and then as it escapes out the hole it cooles again as it expands (the act of compressing air heats it up, and decompressing it cools it - thats how a fridge works) this cold air is going back into the intake. this cools the air between the AFM and the turbo.
and yet another positive is that when the hole is blocked the vacuum created in the return hose can cause the bov to be sucked open slightly (that is the theory behind the mod in the top post of this thread). this is 1 of the design flaws of the stock bov. since it is a flat plate, the moment it moves it leaks boost. most aftermarket bovs have a plug that has to move a few mm before it will release air, so the vacuum has less effect on them.
the only other downside to the stock bov is the fact that when the hole is open it takes longer for boost to build. when it is blocked boost will build quicker, but i found that more boost bleeds off due to the hole being blocked, but that may just due to my bov being weak. i did scuash it a bit and it held better, but i find the release of boost is quicker with the bov unplugged.
will take 1 tonight. i just took it off, got a big socket (about a 21mm) sat it on the top and gave it a few medium strenght taps. now i don't mean medium hits, as if you were trying to break something off, but taps, like tapping a nail in. you use gentle taps to get the nail to go in a bit so it holds itself up, then slightly harder taps once it is about 1/4-1/2 way in. you only need a few taps to do it. you will see the top start to squash in.
Please note: i take no responsability for BOV's that are damaged by this process.
interesting thanks Mad, i have been doing some testing also and pretty much confirming most of your notions.
to properly crush a bov use a bench-vise. it works to crush it perfectly semetrical, crush it until the outlet pipe is flush with the top of the hat, in better words, when the pipe touchs the hat your good.
I am also new to RB motors, so you may have to excuse me.
I would like to know if there is any decent proof that this standard BOV does leak at higher boost levels..?
You compared it to a wastegate, which is completely different, if the wastegate can't flow enough, then boost rises.. The opposite doesn't apply for a BOV.
And as you stated, it works based on the pressure difference from either side of the throttle plate... Therefore, no matter how much boost you throw at it, it will still remain neutral with basically identical pressures both pushing the BOV open, and holding it shut. (So, because of the internal spring it will stay shut).
Unless this device is built to act as a POV ((Pop off valve) don't know if they're still called that).
The POV was featured on most of the earlier turbo cars, 70's & 80's.. It's purpose was to vent excess boost pressure if the boost got to high. So if you have a failure with the wastegate system of the turbo, the motor wont then be forced everything the turbo can throw at it. :) sorry if that didn't make sense.
Or perhaps because of higher boost, and inlet modifications, the internal spring can't hold the small difference in pressure because of a big front mount cooler etc.
In that case, why not run the vaccum hoses from somewhere else..? (hook up 1 either side of the throttle body, or at least both hoses from the same side of the cooler (after it))..
Or if it is meant to act as a POV (or whatever), why can't that bit be removed/disabled from the BOV...?
Now I'm confusing myself even more....
Hope all that made sense to somebody, coz I aint proof readin...
the reason why the BOV will creep open is due to the force of the air passing by it, not pressure, and the vaccum of the plumback pipe sucking it open. and it is getting direct pressure by the air passing by it, where as the pressure holding it shut is coming through a small tube.
also once there is a slight leak, the air in the pressurised area will try to escape out of the place where the leak is to a lower pressure area.
quick question bit off topic... but why on some occasions do i see people use the TBO rubber caps to cap off the BOV and the BOV outlet piping.
Edited by 4DoorWhore
because they are idiots. plain and simple.
they do it for 2 reasons other than that though.
1. to make it flutter
2. to stop it leaking boost, and make it spool up faster.
the down side to blocking off the bov completely is that you have much more lag on gearchanges (unless you don't lift off the throttle). if you have an auto then it is ok to do it, but the immediate response if you lift off then step on the gas again will be slower.
you probs wana becareful if you do this... or maybe not squash it to much...
hehe i learnt the hard way :blink: I did it to my bov the other night.. i squashed it so the outlet pipe went as far down as it could go without bending.
Anyways now after i change gears and put my foot down, boost builds up realy realy fast but it takes the car like a second or 2 to actualy start moving... :D
goto find another bov now :(
i think the bit about crushing it till the outlet pipe is flush with the hat should be removed. i seriously think that is too far as well. sure it would stop the bov from leaking, but it will also limit the amount of air that can escape, so people running higher boost are going to get more lag on gear changes.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
