Easternats
I didn't even see the dyno challenge or the street drags. saw a few burnouts and go to whoa. The cruising on the track was awesome. They pulled us off the track just when we had a good line up of cars - there was me, then a white R34 GTR a couple of R33's & R32's and some VL Turbos. I was spewing - wanted to see how I went with the R34.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-292719
  • Replies 78
Guest INASNT
The dyno comps at easternats are always crap, the finals were meant to be on sunday at around 12-4 but no 1 showed up!
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-292721
Well I assumed all power figures were rear wheel, the owner said it was loosing traction on the dyno so they only rev it to 7000rpm and not 9000, the car has produced it's best figure of 680rwhp and 580awhp in QLD, apparently all work was done by SUBZERO his bro-in-law, lucky boy.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-293663
hi guys im the guy with the GTR R34, the white one...it was sure very fun..i was there sat and sun, saw u BIGPSI, we even spoke....;) saw more skylines out there. On saturday there was a R32 GTR that was pretty good too, besides the 32 there werent any GTR's...;)
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-294437
Guest INASNT
saw your car run in the street drags and when u won those races the people in the grandstand were cheering u (I was standing on the bottom level), i was surprised as u beat holdens and fords and those guys love their holdens and fords.
What can u pull down the 1/4?
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-294882
Guest INASNT
im not sure how fast it does 1/4 miles but the corolla with the v8 engine i dragged does it in mid to high 10's, so it should be around there i guess...
hmm that corolla didnt look or sound like a 10 second car. U r gonna have to be packing some serious turbos and other mods to be in the 10 second bracket in your 34.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297803
that corolla with the big 8 would be around 1000 kg's i'd imagine.
power to weight it would have the edge over most street cars.
gtr-34 what mods you got done to your beast.
i saw you drive through the tunnel and take off up the first straight. very nice, and you did get cheers when you won, but you also got cheers when you lost. hehe.
cars looks mad though, and if you dont mind telling us, how fast did you get up the main straight, you over took most people from what i could see.
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297816
Went to Easternats on Sunday too, great day to be out. Saw the R34 GTR and actually had a chat to him in the car park. Good effort though, a 'P' plater driving an R34 GTR.
He told me that his car is standard except for full exhaust, filters and boost (14psi).
Come to calder next Friday GTR R34 like you said you would, I wanna see you pull a ten second pass......
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-297848
no i believe a corolla with a rotary or something in it will do 10's easily enough just because of the weight..
An R34 GTR is definitely rocket fast.. I'd never say it wasn't. To do 10's it still needs a fair amount of mods however... What has yours had done to it GTR-34 ?
https://www.sau.com.au/forums/topic/13462-easternats/page/4/#findComment-299570
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
