RPM Performance - Sat' 31st May Drag Day - post here if intending to enter
As you can all see from the thread title change - Ivan has booked us in for Sat' 31st May. It was the first weekend in May AIR had available!
Pricing will follow soon. Naturally the more cars the cheaper it'll be. If the 31st is wet then we'll re-schedule to the following weekend & so on... Hopefully all will still be able to attend if the date has to change due weather.
  • Replies 111
Nightcrawler, thanx for the forum web address. Must say I've been browsing Skyline web sites for awhile and never come across this one so I'm stoked. What time did you end up running?? Also, you'll have to drop me a line next time you guys go for a cruise.
Munro - i wish it was me in that bracket, I've never got to see a good view of your runs, what with the constant line up. A run next to a 9 second car, at least for the first 60 feet would be awesome!!
32godzilla .... my best run was the first one - a 13.41 @ 104.5mph - 1.932 60' .... the other 2 runs I missed second gear on both :) for 13.816 (to beat a thumping V8 Commodore :) ) & 13.914
For videos of 2 of my runs and 2 of Munros (incl. the Aus record run) go to: http://briefcase.yahoo.com/bc/andnus2002/l...rc=bc%26.view=l for downloads (sorry about the sizes of the files). Enjoy
Yeah Matt the vids came out pretty well. I loved my launches but was sorry to see you bog down ;) .... you definitely need some :burnout: on your launch!!!
The vids also show how much you pull on me top end - I still can't for the life of me figure out why that is so????
Just goes to show I need to get a cooler in before the drag day :) :shake:
tN^,
I'll put you down on the list I'm keeping mate. Anthony & another GSR/EVO club member are already on it. Ivan is keeping me informed of ALL entries so my list stays up to date.
Cheers,
Matt
Just a thought - has anyone organized a tow truck or recovery vehicle?
might come in handy at some stage, especially with 50 odd cars.
I reckon it would be hard work pushing a car back from right down the end:D
Chris,
I'll add that to the list of things to ask AIR about. They "should" have a vehicle for recovery as part of the track hire fee!?
grepin has volunteered to use his R33 as the tow/recovery vehicle.
As you may recall it's been specifically tuned for that purpose, that Power FC and OS Giken Twin Plate Clutch combo will finally be put to good use.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
