Some parts that where going or used in my r32 GTR no longer needed.
1) R32 GTR fuel pump with strainer, replaced with bigger pump - $100 perfect condition $80
2) New hi filled R32 GTST after market side skirts Mspec style - $180 ONO needs to go
3) Stock R32 GTR skirts - $50 gunmetal grey
4) Apexi Exhaust Control Valve with flanges, approx 6inchs long 3inch pipe - $100
New parts added -
6) HKS POD filters x 2..suit z32 AFM filter elements only done approx 8k asking $100...note one of the top screws was replaced with different screw to hold down the metal mesh.
Parts just laying around doing nothing!
https://www.sau.com.au/forums/topic/134836-r32-parts/
AM putting these parts up again as cant find my other ad?? anyways here are some parts available and in sydney.
1) UsedR32 GTR fuel pump - $100 up on sale again cos of time waster.
2) New hi filled R32 GTR after market side skirts - $280
3) Stock R32 GTR skirts - $80 gunmetal grey
4) Brand new Drift Race seat with carbon back - $550
5) 2x17inch tyres Dunlop 300 235x45 99% tread - $250
6) Used hi flow cat around 10K - $70
Prefer Sydney pick up as some items are big but for pump/cat can send anywhere.
Hi
I'm interested in the larger skirts - but I'm in Brissy - let me know if you will ship
https://www.sau.com.au/forums/topic/134836-r32-parts/#findComment-2506276
  • 5 weeks later...
  • 4 weeks later...
  • 3 weeks later...
2) New hi filled R32 GTR after market side skirts Mspec style - $180 ONO needs to go
New parts added -
bump new prices
https://www.sau.com.au/forums/topic/134836-r32-parts/#findComment-2778697
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
