ahhaah sideways.. porgie will not hesitate in goign.. just tell him when and where.. id come along but i got a night of counterstrike planned :)..
hahaha actually its kinda funny.. u know u got problems when u would rather play counterstrike all night rather then see ure gf:D... ahhh im a prick:D
Originally posted by URMINE
ahhaah sideways.. porgie will not hesitate in goign.. just tell him when and where.. id come along but i got a night of counterstrike planned :D..
same here, sometime I prefer to lock myself in garage just try to avoid see my wife...especially now it's count down 8 days to go, now tell me why you don't wanna to see her...
hahaha~!:P
PS2 Vs Old Road Skylining...uuummmmm
ley me think about that one...
SKYLINE!!!!!!!!!!!! Anyday.
Unless anyone can find Janes Combat Sub Simulation U541 or something like that!!!
Would the meeting point be Thronleigh Maccas ? I'm a maybe....might have to put the silencers in to keep the cops happy.
umm, i can't go to the old road. both my exhaust mounts are snapped off so no hard driving for me tonight. i was thinking of a city drive and then head out to Lazikos for some awsome food. it's out at Auburn and has a good mix of food including the best burritos you'll ever try
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
