There hasn't been that much coverage of it here (London). Steve Irwin had more coverage. Nizmo is right, he is the type to laugh it off. He is still critical but now stable. No information about injuries sustained have been released.
Hey Guys,
Another update for you all...just heard on the news that he is now listed as stable, and not critical.
They are investigating the BBC about it now...here is an extract from an article:
"The police and the Health and Safety Executive will now try to establish whether Mr Hammond should have been allowed to take charge of the dragster in which he was trying to break the British land-speed record.
The BBC could face criminal charges and fines if they are found to have failed in their duty of care to Mr Hammond. "
were they taping at the time? it would make some good tv
Yeah they were filming at the time. It wasn't an official British land speed record attempt. I watched some footage of the result of the crash. You can see the marks on the runway veer off and then the ruts and roll points in the grass. Will have to find it again and link it up.
Its crazy..
You cant blame the BBC, its the hosts of the show that take these risks to get a bigger audience, I understand what your saying however.
Big fan of Top Gear.
Hope he gets better.
I agree with you totally Alpha...I dont see how BBC could get charged over this. What would they say if it had of been a professional driver doing the driving on the show and the same thing happened? If it was a blowout like they have hinted at, it would have happened no matter who was driving.
It is a great show, and I hope that because of this they dont tame it down...that will destroy the show.
He has now got out of bed and walked around and spoken
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
