I pm'd him with a couple of requests, he got back to me with the first but I had to resend another pic but he didn't get back to me on that....I have a couple of mates both with a mate of theirs that do this sort of thing so I'm hardly desperate for it!
ossie 21 - I don't care who makes the nismo stripes (nismo only sell them for the March and Powerplay Imports have them for R34's) I just want them. If your friends are into this type of thing you should point them at this site - looks like he already has customers for something like seven sets - I can only assume that they like money unlike D1 and Dean. (the list is growing!)
  • 4 weeks later...
Okay guys one thing straight i am not guarantee 100% like the other people but i have spoken to my mate and he has said his family business can make decals. I have forwarded him those examples on the D1-zone link and he confirmed it can be done.
He requires a 'vector file' for each image requested. I can do this with him (i think) but what you guys need to do is decide on the 2 or 3 'strips' that are most popular. Then i can judge demand and see whether it is a cost effective excercise or not. Obviously the higher the demand / the cheaper it is for everyone!
So.....
Finalise which images you want.. group decision
and i will get some pricing :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
