Car's gone and now it's time for this stuff to go.
Sydney buyers prefered but might ship interstate at your cost.
1. 2nd Hand Dash Vents to suit R32 SOLD.
2. Pair of Cusco Upper Arms to suit R32 GT-R & GTS-T. SOLD
3. Blitz BOV & Pipe to suit R32 GTS-TSOLD
4. NISMO Braided Clutch Line to suit R32 GTS-T SOLD
5. OEM R32 Handbrake Boot SOLD
6. RB20DET Crank Angle Sensor SOLD
7. BOSCH H3C Low Beam Headlight Globes SOLD
8. RB20DET Fuel Injectors ( 5 Only ) SOLD
9. HKB Steering Wheel Boss Kit to suit R32 GTS-T SOLD
I'm in the Sutherland Shire area of NSW.
Check out my Trader Feedback !! and PM me if interested.
https://www.sau.com.au/forums/topic/135669-r32-parts-garage-sale/
Hey Scott, hold the dash vents for a day? Ive PM'd this thread to a mate of mine who has cracked vents :)
Cheers
(If he wants them ill swing past and get them, im in the same area)
Cheers
No probs :)
i'll take both blitz bov and boost gauge if interested contact me on 0401979449 will most likely purchase on the day you call :O
Edited by --{TRYDIS}--
i'll take both blitz bov and boost gauge if interested contact me on 0401979449 will most likely purchase on the day you call :D
Have returned your PM. :mellow:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
