  • Replies 51
Posted Images
changing to billet custom cams now due to tommie not making larger ones
and am upgrading to a direct port nitrous kit instead of a single
also upgrading ignition to Pro comp with CDI boxes
once its running within 3-4 weeks i will post new hp & torque graph and will hit the track
we are also making customs arms for the IRS and bushes to help the car launch.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2581239
Sounded like you needed the CDI with the spark not up to all that fuel.
Keen to see the on track result from such a beast.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2581268
the cams that are supposed to be in it was
270 @ 10.8 lift
but the ones in there are 260 @ 10.25 lift the supplier made a stuff up and i didnt check them before i got the head done
so the head had to come off again and i have to re do the Tappet clearances AGAIN what a headache.
The new cams will be around 280 @ 12.0mm lift
but i will have to see what is good for the combination.I still working out a exact set but i will post how i go.
The CDI boxes and new coils should hold up to 40 psi from what i am told .The 707rwhp dyno was done at 30 psi with poor ignition system and rich afrs
so hopefully i can making more power without pushing the tune.If i can make 750 ill be happy and just run the car at that and then if i get bored pump more boost into it.
i weighed the car and it weighs 2890 pounds with a full tank of fuel and nitrous so its not light but its not heavy.
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2583183
With the car around 1310kg and 700+hp at the wheels should be good for the low 9's with around the 145mph region.
Would be awesome to see a good old Rb25 doing those kinds of times... Can't wait for the results hope you sort out your CDI System. Keep us posted !!
https://www.sau.com.au/forums/topic/135859-lnemup/page/3/#findComment-2596295
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
    • We want to see pictures of the carnage!
    • The picture of the underside of that PCB shows either old flux that wasn't cleaned properly or some other contaminant (I.E Water). I would flush it with ISO and try again.
    • @silviaz Are you skim coating the entire panel (covering the entire panel with filler) before your hitting it with the long block? Or are you selectively applying filler to the repair, trying to fill the low points?  Please don't do that.  Almost certainly. Are you checking the panel for flatness as you go? Or is it more a case of, sand til all the guide coat is gone then check?
