Hi all
Found 2 types of pads I am interested in. Have spoken to many people and they all recommend the Endless SSS pads.
However I also stumbled across the SSM series pads which are slightly more expensive. From what I can tell they are very similar pads except that the SSM have very low dust. Supposedly the SSS have low dust as well, but if there is a SSM, then maybe it is not so low after all.
I am looking for anybody's experience with the SSS or SSM and their dust levels and braking performance.
Specs are:
Super Street S Sports
Temperature Range: 0 ~ 500oC
Average Coefficient of Friction: 0.35 ~ 0.43
Super Street M Sports
Temperature Range: 0 ~ 530oC
Average Coefficient of Friction: 0.30 ~ 0.40
Anybody know what the difference in friction coefficient will translate to on the street in terms of braking?
I am looking for pads for the street, with low low dust, not noisy and a good initial bite that does not fade off overly quickly.
I know compromises will have to be made because you cant have it all. My current pads (Formula Ferodo) are great, but just too dusty.
Thanks
https://www.sau.com.au/forums/topic/135938-endless-sss-or-ssm-pads/
well i would say with a lower CoF the SSM will be less effective, not by much, but definately a little less effective. They both have quite wide ranges of both CoF and operating temp. so they will both be good on street, but not so good on track. i've used the SSS and they were good on street. very quiet (no squeal at all, ever) and not too dusty (nothing like bendix ults etc). quite a soft pad too so they wont chew out a rotor when cold.
How dusty is not too dusty BB? My wheels get a tinge of brown dust with my current pads after one day in the city. A week after, they are pretty much fully brown haha! Quite annoying.
Also how were they on the initial bite? ie. did they wipe off alot of speed quickly?
Finally, my current pads have a average coefficient of 0.43, how will the Endless pads compare then? less effective I guess?
Edited by nuffsaid
well it's not just about a raw CoF number. you need to consider the range, and the temperature that it can operate effeciently in.
i really dont know how to quantify dustiness other than to say i didn't think they were too dusty. for example i currently use endless CC-R for track work and they are crazy dusty, and LOUD and dont stop at all when cold.
the endless SSS are a fairly good pad for street/spirited street driving.
Argh I guess coefficients are hard to make a decision by because they operate at different temps like you said.
Best thing to go on is experience then.
BB: in comparison to say Bendix Ultimates how dusty are the SSS? I think the Ultimates are almost on par with the current pads I have in terms of dustiness, except its more of a fine brown than black dust.
Okay just found out my current Formula Ferodos are 0.46 coeffecient with temp range from 0 to 650 celsius. I am guessing the endless pads wont be as good then.
Although because they are cooler pads, they would probably have a nicer initial bite, and hopefully less dust than the Ferodos
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
