Item: HKS 2535 Turbo + all oil lines etc to bolt up
Item Condition: Second hand
Reason for Selling: Rebuild and upgrade
Price and Payment Conditions: $1400 ono
Contact Details: PM or post
Selling as i blew my engine and am going to do a slight turbo upgrade as well :) . Turbo has been on car for the last 4 years and has never run over 1.2 bar. Only ran 0.5 - 1 bar on the street with the occassional 1.2 bar at the drags. So has VERY rarely seen even 1.2 bar. :laugh:
Made 249rwkw at hitmans with supporting engine mods, and was tuned down to make a safe 235rwkw at UAS. Can supply dyno graphs if required. :w00t:
If anyone wants to check it out feel free to organise to see it. My mechanic looked at it and said it is in good condition. Pics to follow :sorcerer:
Details on turbo can be found here :
http://www.hksusa.com/products/?id=705
https://www.sau.com.au/forums/topic/136001-hks-2535-direct-bolt-on-for-rb25det/
pffft its a fake :laugh:
hahaha only joking mona....
I have driven the car on many occasions before the engine blew and I have to say this is one AWESOME turbo for an RB25 and with the hassle free bolt on nature of it, its a good buy :)
Im after a tad more power :w00t: which is why I havent bought this turbo already.
New owner wont be dissappointed....
Hi All!
Also wanted to point out the times I was doing at WSID with the above turbo and supporting mods.
Best time I managed was 12.504 on street tyres, and with the two runs I got with semis i managed to get her down to 12.4. I sure with more runs, this time could have been further lowered! Note: all runs were only ever done with a max boost of 1.2bar.
So as you can see, an awesome power mod all round! ;)
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
