Hey guys.
Ok so ive established that the Justjap JJR intercoolers are good and worth the money ($550 for a type 2 kit)
My goal is:
FMIC + Exhaust then crank up the boost.
Good idea?
OK lets say it is :laugh:
I completed my tax return today, should be getting about $900.
Car is almost stock, except for a POD and BOV.
My Dillema is, do I go for the exhaust or Intercooler or something else.
Can only afford one at this time.
The Exhaust i had my eye on was the X-Force 3.5" Turbo Back system ($799 for mld steel, $950 for stainless steel)
The Intercooler kit im also looking at is the JJR Type 2 Intercooler kit.
So if I could get peoples thoughts on:
*Zorst, FMIC or other
*What effects will each have on my car
*Any other sugestions you feel are relevant
Thanks guys :kiss:
https://www.sau.com.au/forums/topic/136284-dilema/
Whats this split dump buisness? (don't know what that means :laugh: )
Also would there be much difference between a 3" and a 3.5" system?
X-Force does both the 3" and 3.5" turbo back.
Im thinking X-Force mainly because I had an X-Force cat back on my previous car and it sounded great.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2534076
do a search on split dump pipe and you will see... the split dump seperates the wastegate gas then rejoins about 40cm down the dump... makes big difference to a single bell dump..
i wouldn't go anything bigger then 3" on the exhaust... unless ur running twin turbo or have 400+rw/kw
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535035
good way to spend $900 in my opinion:
- full turbo-back exhaust
- turbotech boost controller set to about 10psi
- oil and sparkies changed
- 1 hour on dyno to adjust the timing
you want a 3" exhaust.. no bigger, no smaller...
probalby the greatest mod that one could EVER do to a turbocharged vehicle...
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535060
turbo back exhaust, then front mount followed by boost and then powerfc it to get maxium bang for buck - but its gonna cost more than 900
Edit: X-force has a nice rumble to it, depends on what you want - quiet or loud.
Edited by emsta2003
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535127
I want loud...ish.
As in, legal and not overly droney.
Does anyone know if the X-Force has this split dump that was mentioned? If not, any other reccomendations on a full turbo back system for $900 or less.
Also is it worth paying more for stainless steel? Ive heard mild steel is more than fine for many years.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2535767
you can get the split dump front from batmbl (hes a member on these forums), and then just get the cat back from x-force and attach it to whatever cat you got running
thats going to work out much more expensive than the full x-force kit, and not give much of a power difference.
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536089
Ok well theres the Xforce turbo back
$799 for Mild Steel
$950 for Stainless steel
Theres also the JJR Split dump for $125
Whats the difference between a 'front pipe' and a 'dump pipe' ??
Does a split dump make a big difference?
Again what sort of difference would I notice going from stock to the full Xforce turbo back
And what difference ontop of that would I notice if there was a split dump?
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536131
no you wouldn't notice the difference between a split dump and a bell mouth dump.
the dump pipe is the pipe off the turbo. the front pipe goes from the dump pipe to the turbo. the x-force pipe is a 1 piece pipe. it has both in the front pipe.
the jjr dump pipe also requires a front pipe.
Edited by mad082
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2536294
how can you dyno tune a stock ecu though? didn't think there would be much gain to be had.
i didn't sasy "dyno tune" i said time on the dyno to adjust timing
a dyno is just rollers so that the car can be driven as on the street but still monitored (eg listening for pinging)
with the car strapped to the dyno the mechanic can see how the engine runs (eg is it making the right amount of power?) and adjust the CAS to change the base timing (give it more power!)
this usually costs around $100-110 depending on the workshop and is highly recommended
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537336
i agree with mad082. get an x-force turbo back system, get a bleed valve and set it to 8-9psi, maybe even 10. the standard side mount shud support this, but if u want to be more safe and economical, buy a gtt side mount. after this u shud pick up at least 20-30kws at the wheels
https://www.sau.com.au/forums/topic/136284-dilema/#findComment-2537999
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
