my 32 is basically stock, sept for usual, apexi pod filter, 3 inch exhaust, really thats all thats going to effect a tune, things like the brass button clutch and coilovers dont have anything to dowith the tuning process do they ?
basically im wondering if you an 'tune' a stock ECU ?
if so is it worth it ? should i just wait til i buy an APFC ?
if it is possible/worth a tune with stock ECU i will buy an AVCR too
just want some opinions on what i should do. :D
https://www.sau.com.au/forums/topic/136355-is-it-worth-a-tune/
OK... first off, for the mods you have I wouldnt worry about it, theres not enough there for it to be worth your while.
No Coilovers and a Brass Button wont make a difference to the tune itself.
Yes you can tune a stock ECU - look up Dr.Drift he does wonders with them.
If you buy an AVCR and decide to crank some boost in, it might then be worth a tune, just to make sure your fuel supply is going to be sufficient enough to support the increased boost. In saying that on stock items with minimal mods one would hop your not going to be pushing enough boost to require a tune anyway or your going to have dramas regardless.
Its also handy to remove the limiters on the standard ecu, the dreaded, boost/fuel/speed cut etc.
But for now bottom line is: Concentrate on other mods first off, a nice front mount, upgrade your fuel system then wind in some boost, maybe look to upgrade to an RB25 turbo things like that, your money could be more well spent :D
ahh yeh forgot to mention front mount (i got one) :D. thaks for the reply mate, helps a lot as for what i should be looking at :mellow:
i think i will do as you suggest and upgrade turbo and fuel system before i get the AVCR and a tune. thanks for the opinion !
Edited by thrtytwo
If you want to be safe, do the fuel system first then the turbo + boost that way you wont be leaning out your engine which can cause detonation and a whole lot of other nasty problems you dont want to have :D
Upgrade the Fuel Pump + Fuel Regulator and you should be right the standard injectors and rail will be enough for a basic turbo upgrade to something like an RB25 turbo. If your pedantic like me, might be worth upgrading your almost 20 year old crusty fuel lines and the filter while your at it, they are relatively inexpensive and just gives you a nice fresh platform to work with.
If you want some budget items, grab yourself a GTR Fuel pump they go straight in and offer a great budget upgrade, a nismo/sard regulator will set you back under 200 dollars and your local repco will be able to provide you with fuel line and the filter, then you can rest easy knowing you have the support systems from which to base future mods.
After that definitely look at an RB25 turbo, either stock or highflow and the AVCR. Using your fuel regulator you should safely be able to up the boost to a respectable 1bar with the AVCR and see no problems with your engine as long as it is well looked after, and still be able to avoid a tune or great need for aftermarket management, although it never hurts :mellow:
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
