FOR SALE - SYDNEY
White 1994 R33 GTSt Series 1
$11,000
165k Kays
5 Speed Manual
AVS Copy Wheels
GTR Copy rear wing
Turbo XS Bleed Valve - Set too 11psi
Kings Springs all round
Tyres about 60-70%
Rego May'07
Needs Work - I would say for next Rego..
Work Includes :
New Power Steering Pump
Clutch maybe
Muffler has a small hole in it.
A few marks on the body.
The car drives normal as it should even with the above. I'm just being up front.
The car has never given me any problems at all.
PM or call 0406 573 273 (Leave a message please)
Edited by AndyMac
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
