Hi All
I have thinking of installing an oil cooler in my car, since summer is on its way.
Can anyone one tell me who has a oil cooler installed in their car, When you change your engine oil dose some of the oil remain in the cooler, and if so would be better to have a drain plug in the oil cooler it self to drain the remaining oil.
https://www.sau.com.au/forums/topic/136430-oil-coolers/
Confucious say:
Change coolant to your a good of mix anti freeze boil anti to help heating of the not, a-sohn! *goooonnnnnngg*
exit Confucious.
I just did the whole she-bang, CP 3-core rad, both hoses, a Nismo 62deg thermostat and Castrol AF/AB arond 40-45% mix with distilled water.
https://www.sau.com.au/forums/topic/136430-oil-coolers/#findComment-2539960
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
