which head is best?
Guest drift_me_silly
no msn on this machine, swapping labs in an hour...i'll try msg u then...where do you go to drift around here, who do you use for mech. work, how do you afford the sweet machines that are skylines? -i'm in the making of a career...namely mine...as i said.
in time.
If the rules are still the same, then the head off a larger capacity engine will cause a REDUCTION in C/R when fitted to an engine of smaller capacity (presumably the combustion chambers are bigger on the bigger engine). Now, this may allow you to run more boost, but the engine will be far less tractable 'off-boost'.
It was often the practice in the days of L-series engines to do things like fitting a L-16 head on a L-18 block to get a bit more compression.
If you are after serious grunt, then trying to fit the RB20 head on the RB25 seems more the way to go. Or you could simply port / polish a RB20 head for your RB20 block so that it breaths better.
Hi guys, RB25 and RB26 are 86 mm bore and RB20 is 78 mm bore. So if you try and put an RB25/26 head on an RB20 block you will have a mismatch in diameter of 8mm. The water jackets are in different places and, if I remember rightly, the oil galleries are different as well. That's why there are none around.
Want more capacity out of your RB20? Try an RB26 crank and rods and 4AGZE pistons, makes 2,336 cc's. There's a lot of info and discusion about this in the past on the forum, do a quick search. Also www.meggala.com has a lot of info as well.
Hope that helps.
Hi S13 Silvia, suggestions follow your questions.............
***What do you reckon would be a good price for rb26 crank and rods?
Shop around the forum they come up from time to time, prices vary from $200 to $500
**Is it possible to use the rb20 pistons with the rb26 rods?
Never tried it, I know the gudgeon pin is larger diameter in the little end of the RB26 conrod. You could either machine the piston for a larger gudgeon pin or bush the RB26 little end for the smaller RB20 gudgeon pin. Either would probably work OK, I would lean towards the former as a larger gudgeon would be better as long as the necessary machining doesn't weaken the piston too much.
**What's the availability like on getting the rb26 crank/rods?
They come up from time to time on the forum. Be watchfull, act swiftly, as they seem to sell fairly quickly, and have your money ready.
Hope that helps.
Hi drift_me_silly, check out the posts by JOnJOn he has a 2.4 litre RB20.
Watch the costs though, they add up and can easily exceed the cost of doing up an RB25DET.
Good luck, let me know how it goes.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
